21 - 40 of 72 Posts
Seems we picked mostly the same things to watch. As you can see in the screenshot above, I have trans fluid temp monitored and didn't have to create any custom pids to do so. I just tried adding the ones available until 1 worked.
Very interested in what other pids you find.
The system did behave in an odd way last night. I had left it plugged in last night while the car was off. Its supposed to power itself off. At 4am, my phone kept beeping. It kept complaining it was attempting to pair with the OBD2 device and failing. My bedroom is above the garage, so might be close enough for the Bluetooth to see the adapter, but not close enough to establish a connection. Why this started at 4AM is a mystery as the phone had been in the same spot for 8+ hours and the car had been in the same spot as well.
Well - I learned a couple things today.
1) PID 0105 isn't the transmission temperature because it mirrored the coolant temperature (PID 05).
2) Intake Air Temp (PID 0F) appears to come from the MAF and reads much higher than the actual intake air (not even close to Ambient Air Temp). With an ambient air temp of 86*F, the Intake Air Temp was 120-140*f. It is almost like IAT2's on boosted cars in 86*F ambient air. :blink: I suppose the IAT relocation kit is worth it?!?
3) I performed a full PID scan (took about 1 hour) and got some disappointing news. The scan captured 4221 PIDs, but it appeared to skip all PIDs. This seems odd, so I checked with another OBD2 ELM327 Adapter and I had the same results. I'll explain more below:
Here is a snippet of Mode 22 PIDs:
Command: 220001 response:7E8 03 7F 22 12
Command: 220004 response:7E8 03 7F 22 12
Command: 220009 response:7E8 03 7F 22 12
Command: 220010 response:7E8 03 7F 22 12
Command: 220019 response:7E8 03 7F 22 12
Notice 220002, 220003, 220005, 220006, 220007, 220008 and others are skipped? I found this odd, because the skipped PIDs could have data. So to expand further - here are a couple examples of known working PIDs not included in the full scan by Torque:
Oil Pressure - PID 221470:
Command: 221440 response:7E8 03 7F 22 12
Command: 221451 response:7E8 03 7F 22 12
Command: 221464 response:7E8 03 7F 22 12
Command: 221479 response:7E8 03 7F 22 12
Command: 221490 response:7E8 03 7F 22 12
Skipped!
Another example - Oil Temperature - PID 221154:
Command: 221140 response:7E8 03 7F 22 12
Command: 221151 response:7E8 03 7F 22 12
Command: 221164 response:7E8 03 7F 22 12
Command: 221179 response:7E8 03 7F 22 12
Skipped again! :question:
I then went to the Torque forums, and it appears that skipping PIDs is not abnormal. I find this strange because there are valid PIDs not included in a 'Full Scan'.
I've done a brief amount of searching for Transmission PIDs for LS3 PCM/TCMs. I've added Transmission Temp GM Method 1 (PID 221940) and I'll observe it in the morning. For Transmission Temp GM Method 3 - torque has been performing a calculation for Transmission temperatures based off the coolant temperatures instead of finding the true PID (if one exists). Considering Automatic SS's will have a PCM for the transmission, I wonder if the value is in there and passed over CANBUS to the engine PCM? Anyone with HP tuners taken a look at this or maybe tuners have come across it?
Thanks!
I got the same results when I tried to scan all the PIDS, everything returns the same value, 7E8 03 7F 22 12.
I do have trans fluid temp working properly, or at least I think I do. The temp reported is the same as all the other fluids in the car from a cold start after sitting overnight. Coolant temp rises pretty quickly, reaching 190+ within a few miles of driving. Oil temp takes much longer to reach full temp, at least 10-15 minutes of driving in 70 degree ambient temps. The trans temp rises still slower. It does not track either coolant or oil temp directly. I haven't seen a trans temp above about 165 and that happens when the car sits while off after a drive while heat soaking. Coolant temp regularly sees 210 and oil temp 215 to 220.
Here is how I got trans fluid temp to display in the torque app. Go into settings and choose "manage extra PIDs/Sensors". Then from the three dot menu, select "add predefined set". In the resulting list, choose "Pontiac/GM/Opel/Vauxhall". That added 2 custom PIDs name "Transmission Fluid Temp (GM Method 1)" and "Transmission Fluid Temp (GM Method 2)" Both refer to PID 221940 and have equation A-40. The only different is the OBD header which is "Auto" for method 1 and "7E2" for method 2. Now these PIDS are available for selection when you add a monitor. Method 2 works of me. On the screen to "add sensor" when adding a display, both method 1 and 2 are green, showing torque is getting data for them. Both show 32 degrees F. If I select method 1 then the monitor doesn't work, it just sits at 32 degrees. If I select method 2, the first display is 32 degrees, but within a second or so it displays a real temperature. Once the monitor is configured, each time I start up torque, it gets readings for the trans fluid temp that are realistic, so I believe they are correct.
Hi!
Thank you much nothingtoseehere! You were absolutely right about using the Trans Fluid Temp GM Method 2! I previously tried Methods 1 & 3, but not 2. I see the same results with Oil temp, Oil Pressure and now Transmission Temps as well. With that finding, I believe we've got a pretty good amount of information that isn't shared via the DIC or stock gauges.
Attached are screenshots before and after engine start up after sitting overnight (cold - mind you, Florida in the summer temps):
Ignore the GPS altitude - the car is in the garage.
I'd like to find the TPMS pressure and potentially discover the Tire temperatures if possible. However, without comprehensible data in the response from a PID scan, I'm unsure where to start unless I start guessing at random PIDs. I plan to make a diagnostic screen to include all cylinder misfire counts and any other valuable diagnostic information that is registered by default with Torque Scan with the Pontiac/GM/Opel/Vauxhall extensions.
Question - have you decided where to mount your phone/tablet to display this information? I'm considering this for my spare android phone that I use Torque on:
and then an Invisicord USB charger off the mirror:
Invisicord Products
Any other ideas for permanent, yet discrete mounting location for a dedicated android phone? I'm considering a V1, and that would be best mounted to the mirror instead of an android phone.
Thanks!
Glad you got it working. See below for the phone mount I'm using. This gives me wireless charging, one handed operation, decent visibility and an easy reach from the drivers seat. I personally don't want the phone in my field of view and right now I don't intend to use the phone for torque only. The phone goes with me and I'll load up torque if I want to see what's going on or data log.
Here is a quick data log of cold start after sitting in garage all night (cold being 78 degrees ambient). I then drove 5 miles around town and back home. This was all warmup and in my neighborhoods, so I drove with the flow and was very easy on it.
Quick hits (green, orange and grey lines are coolant, oil and trans temps respectively):
  • 6 minutes of driving to get coolant to full operating temperature. This included 2 minutes of local 50mph road and then mostly stop and go 25-30 mph roads.
  • Over the 13 minute drive, oil temp had not reached full operating temp and was still climbing, but based on the slope of the line it was close to stabilizing.
  • Trans temp never reached stable operating temp either, reaching 135 degrees and climbing at end of drive.
  • Still looking for good measurement of throttle position. In this attempt, WOT shows about 80%.
Found this on the interwebz: I have not tested it yet:
TPMS Tire Pressure
PID: 22C901
Formula for wheel 1 for psi = ((A*1373/1000) * 0.145037738)
Formula for wheel 2 for psi = ((B*1373/1000) * 0.145037738)
etc.
TPMS Tire Temp
PID: 22C902
Formula for wheel 1 for degrees F = (9/5*(A-40))+32
Formula for wheel 2 for degrees F = (9/5*(B-40))+32
Testing Update:
Tested with Windows-based OBDDesk - no data returned - this is probably not a valid PID for us
Reactions: LilZig
Finally broke down and bought a cheap Android 7" tablet to use with Torque. Fits nicely in front of the shifter, fairly visible, and still easily movable to access the storage compartment.
Further thoughts
So... I got to checking out terminal sessions to the CANBUS as a result of my curiosity regarding the recent FCA Uconnect hack. As a result, I've learned many of the AT & ST commands for OBD2 because the OBDLink MX support it. I'll be picking up a wired USB OBD2 ELM327 module so that I can monitor continuous OBD2 traffic because Bluetooth modules are only able to handle data in bursts and I keep encountering Buffer Full halts (even after filtered tuning). The wired USB adapter will allow for full connectivity without packet dropping due to lack of bandwidth via bluetooth.
I had a revelation (yes, I'm slow at times!) that the extended PIDs we got in response from our full PID scans with Torque revealed all the NULL PIDs (due to the 7F in the response). With that said, all the PIDs that were skipped are suspect to contain data and be functional. I've attached a cleaned version of the full PID scan. I've been able to parse it (omitting the first 8 rows) into excel and I'm going to determine all the PIDs that may have data that are not included in the scan. Essentially, all the PIDs not provided (Hex 0-F) are potential enhanced PIDs.
This will allow us to narrow down the functional PIDs, potentially cross compare any known/mapped PIDs and begin the reverse engineering. When I get the USB ELM scanner, I'll begin trapping communication on the CANBUS to determine if the data points for TPMS pressure & temp are sent from the BCM module to the ECM at all (amongst other traffic). I know that I could switch the DIC from one screen to the TPMS screen and potentially get all the values in one scan session.
This coincides with my curiosity regarding the OBD2 window rollup/rolldown module I got to understand the unlock/lock sequence conversations that result with relaying all four windows to rolldown and rollup successfully based. I plan to get a OBD2 splitter cable to perform this sniffing while allowing the window module to reside on the CANBUS. Below is the thread I updated with that and a quick youtube video showing it's operation. This same module causes the hazards to come on when you open and close the doors (not a bad safety measure when parked on a street).
http://www.ssforums.com/forum/electronics/13170-window-roll-down-function.html
Below are a few primer documents if ya'll are interested:
a complete guide to hacking your vehicle bus on the cheap & easy – part 1 (hardware interface) |
a complete guide to hacking your vehicle bus on the cheap & easy – part 2 (interpreting the data) |
https://cdn.sparkfun.com/assets/learn_tutorials/8/3/ELM327DS.pdf
http://opengarages.org/handbook/2014_car_hackers_handbook_compressed.pdf
As for the devices - I like how you guys have gotten creative with a tablet and phone mounts. I'm considering a mount to the rearview mirror for my android phone for gauge purposes only and a separate mount for my iPhone on the dash. I do plan to get a v1 radar and blendmount it, so I'd like the android torque device to be to the left of the mirror in landscape mode - so I may have to build a custom bracket with parts from RAMmounts.
I'll provide an update once I've made more progress. Thanks!
TPMS Tire Pressure
PID: 22C901
etc.
TPMS Tire Temp
PID: 22C902
Testing Update:
I checked for 22C901 in the full PID scan and it showed up with NULL, so it's probably not of value. However, there may be others in that range that are of value (22C903, 22C905, 22C906, 22C907, 22C908). I will probably learn the extended PIDs for these values once I perform CANBUS scans and bring up the TPMS values in the DIC.
Thanks for the tips on the formulas!
Hi guys new member, who stumbled onto this post searching for some related data. I've been sorting through the HS GMLAN ARBID's in raw data packets for another project. While I often use Torque [great app], I've also been using other scan tools to generate the GM proprietary ID's or PID's I need. Then rather than using an ELM chip, I started logging the "raw" CAN packets to between ECM, TCM, BCM and such with another CANbus tool. This gets ya all the goodies, like the starter sequence sent from the BCM to the ECM once the key has been authenticated. Who needs keys, we have computers.. LOL...
Anyways my hacking around on some 07 and up HS LAN vehicles has shown anything going to the IPC "Gagues" is being streamed out of the ECM or TCM with specific ID's. Including oil pressure, temps, speeds, and RPM. Some are very fast updates, others are about once per second and seem to be padded for smoother display, like oil pressure. The other thing I've found is OBD-II pids don't always match up with high end scan tools like a Tech 2... So I'm trying to build a list of requests and ID's from raw hex data. About everything I've found to date online is from the Chevy Volt guys. But many of the ArbID's the've found don't line up with the trucks I'm focused on. Would be nice to build a list of vehicles that share common ID sets.
Since someone above was looking for oil pressure, and we know it's not in Torque pids, plus I'd personally like to add it, here is the hidden ways I've found it. I just haven't had time to test any of this with Torque. If anyone can do that and help me figure out the exact scaling math used by the IPC, this would be great..
High Speed LAN Raw Data Packets:
Factory ECM Broadcast Msg -- 0x000004d1 -- 00 00 45 02 e9 2a 00 94 -- Scaling is something like (A*100/256)*2 = oil pressure PSI value.. Also in there at Byte 8 (94) is Fuel Level. (A*100/255) = %
GM PID Requested Oil Pressure Return Msg -- 0x000005e8 -- fe 0b 40 79 25 -- Scaling is (A*4) = KPA. The 79 is engine temp I believe. Don't take my word for it.. I had to request more than one PID so it would send return oil pressure info. Not certain why, but here is the raw "3 byte" OBD message captured that got me to that 5e8 line above.
0x000007e0 -- 03 aa 01 fe 00 00 00 00
Someone please give that try in Torque and post up if it worked or not.
PM me with any questions or comments since I forget to check posts.
Cheers,
-K
Welcome to the forum kidturbo!
Cheers,
-K
Torque can provide oil pressure out of the box. Its working as expected for me through torque. Go to settings and "manage custom obd2 pids". Add the predefined set for GM. Oil pressure and oil temp are included in that set, both work fine on my 2015 SS. Oil pressure in psi is PID 221470, equation A*0.578.
Thanks guys.
For the most part I've only tested Torque GM pid set on Duramax engine platforms. Noticed Oil Pres missing under Torque scan, but it's available in EFIlive, Tech 2, and any SnapOn tool. So I though maybe it's just a diesel thing. I'll give that PID a try tomorrow and let ya know.
Originally I was only interested in identifying the ArbID's related to gauge cluster. This could be done "passively" because the data is being broadcast by the ECM without any polling. But the math on Oil Pressure just won't scale to KPA between top to bottom no matter what I try.. All other math like engine temp matches up with standard OBD pids. But it does in come close when PSI values..
Also my post above about 70E data is incorrect. That's actaully a "keep polling" message I believe. I either missed the first request packet, or when in mode 22 all the ID's are different. Back to the sorting table.
Thanks again. I had to add it manually, and verified on a 2011 2500 series truck with 6.0L. Which leaves us least 3 totally different ways to acquire that same piece of information from the ECM...
Don't know if it's out there, but here's a GM ID to try as a Torque [internal_pid]
0x01f5 00:00:00:01:00:00:00
Byte 4 of 8 should be gear selected position. 01-P, 02-R, 03-N, 04-D/6th, 05-5th, 06-4th, 07-3rd, 08-2nd, 09-1st.
Hi guys - what post count do you need to post pic's.
Got some pics of torque pro setup.
:smile
Anybody can post pics. No post count required.
Sent from my SM-G920P using Tapatalk
21 - 40 of 72 Posts
