61 - 72 of 72 Posts
Banks Engineering iDash 1.8 Gauge
I wanted to display the usual engine monitoring parameters that are available on the OBD II CAN Bus, but wanted a permanent display that starts up/shuts down automatically with the engine. Gale Banks Engineering offers this type of gauge, called iDash 1.8. Banks is a turbo diesel specialist, so the product does a lot more than just display OBD II parameters - for example calculates inlet manifold air density which is key to turbo diesel power. It also provides many of the scan tool functions. An attractive feature for me was that the gauge can display up to 8 parameters at a time, and there can be up to 5 pages each with up to 8 parameters. Multiple gauges can be linked to a common data bus, and there is also a data logging option.
I have attached a photo of this gauge installed on my 2015 SS. The limitation of the iDash 1.8 is that the display parameters are picked off an internal gauge menu, rather than by directly entering a PID #. My gauge is set to display engine oil pressure, engine oil temperature, coolant temperature, intake air temperature and battery voltage. When I first installed the gauge, engine oil temperature was not available on the Banks Generic GM menu. I contacted Banks Engineering (with the PID# I picked up on this thread), and a couple of days later I received an email with 12 firmware update files. I copied these files on to a micro SD card, and loaded them into the gauge - and now have the engine oil temperature displayed as well.
So far I have learned that engine oil temperature runs 10-15 degrees F hotter than coolant temperature. Also coolant temperature varies quite a bit more than the dashboard readout would indicate. The dashboard needle stays approximately centered for coolant temperature between 185 and 230F. I first saw this behavior on my 2005 Chev 2500HD Duramax truck, when GM was trying to mask the fact that the truck was prone to overheating when pulling a heavy trailer up a steep grade (e.g., the Grapevine). I have also learned that the Rotofab cold air inlet provides ambient temperature when started up, but then the plastic filter housing located in the engine compartment absorbs heat. When the car is parked for an hour or so, inlet air temp is 60-80 F higher than ambient. This cools down some with driving, but slowly and incompletely. In other words ambient air flowing through the plastic ducts is not enough to completely cool down the system. Now I have a new SS project to apply insulation to the outside of the cold air inlet.
Hi all,
Do the LS3s in the SS come with IAT2 sensors? I'm having trouble with getting a reading in torque pro. I've imported the GM PIDs and managed to get oil temp, but would really like to watch IAT2 as well. Does anyone have the PID by chance?
Mine is a VF HSV R8 (Aussie hsv variant) LS3 with a harrop 2300 FDFI bolted on...
TIA
Sent from my SM-G960F using Tapatalk
Anyone use the OBDLink MX+ with wifi? I just ordered it to begin acquiring data on an occasional stumble on light acceleration. I searched lots of products but what finally sold me was the ability to use wifi while bluetooth was still linked to the car along with the 'stated' 128bit encyption, and some reviews on this forum.
On a side note, I am interested equally in product performance as well as product security.
Frankly, any product that uses wireless can have additional capability included at the hardware level, regardless of the intended use; though I'm not so much concerned about purposeful hacking as I am about passive data logging.
I searched a lot of actual professional scanners (foxwell, autel, innovo, etc) and then I researched six of them and that every single one of the six that I looked at was produced in china, most linked to companies HQ in Shenzhen. I then found that OBDLink looks to be a product of USA and is located in Phoenix AZ, under the parent Corp OBDSolutions.
What other products are people using?
I use the MX+ over Bluetooth so I can't comment on the WiFi aspect. You are going to want to use mode C2 and a filter. I use my PC and open a serial connection over Bluetooth. Using any OBD request/reply scheme will be too slow to capture a stumble as you will get a ~5Hz update rate plus and unknown delay. You can certainly get lucky, but you may record a lot of logs and would have to replicate the issue many times.
I just got the MX+ the bluetooth version which works on Android or Iphone. Haven't done any data logging but it seems like a quality product. I get oil pressure and oil temp haven't messed with trans temp yet. FYI: box says assembled in Mexico.
Awesome! lol I lived in AZ for many years so made in Mexico / Arizona...?‍♂
At least if I'm going to be screwed by someone else's hardware maybe its better coming from a neighbor...
So latency is an issue. I hope the wifi will not suffer from that. Thanks for the heads up.
Has anybody had luck getting Engine Oil temperature and Transmission Oil temperature to read other than 0 degrees with an iOS OBD2 app? This is one time I wish I had an Android to get Torque. I’ve tried Car Scanner and OBD Fusion.
Bumping for this question. I have the oil temp via Holden DIC conversion, but I’d like the trans temp via OBD. I’ll purchase a cheap Android tablet to use Torque if needed, but it would be best to use my iPhone.
Jay from Banks here. Glad you're enjoying the iDash! We'd love to interview you for our weekly newsletter. If you're up for it, please email me with your contact info. Thanks! jtilles@bankspower.com.
Bump
Has anyone found a PID for the brakes? I can get 0, 1 and 2 values but that doesn't tell me much about the brake pressure when trying to compare trail braking at the track.
You can see the brakes are pretty much on or off. Oh and the oil temp is MUCH higher when at the track compared to the street 😆
61 - 72 of 72 Posts
