61 - 80 of 327 Posts
Quick question. I see on the Holden conversion that there is still a little bit of blue from the MyLink at the bottom of the background. Can this be removed for a cleaner look?
Reactions: Afroman
I think the little blue strip is normal. You can see it in this picture here on the Holden site.
Holden Commodore - Image & Video Gallery | Holden
Hmmm. It appears you're right. I looked through the images online again and apparently the blue strip is on the red-background Holden Commodore models, but not on the HSV vehicles as follows:
http://performancedrive.com.au/wp-content/uploads/2013/10/2013-HSV-Gen-F-GTS-instrument-cluster.jpg
http://performancedrive.com.au/wp-c...u/wp-content/uploads/2015/01/2015-HSV-GTS-Maloo-instrument-cluster-1280x851.jpg
It just looks off with that blue strip and that's something that would really annoy me.
Reviving it again haha. Anyone have any videos of the 0-60 timer? Does it automatically calculate, or do you have to click the Set/Clr button on the indicator to start and stop it?
It automatically stops you press the button to set it and it will turn off at whatever speed you set.
As far as the blue "stripe" on the bottom the color is very much exaggerated by the camera but yes it is still there. I honestly think it looks fine but thats just me. I'm always a purist for those sorts of things so if the car has it in the Oz market i'd want it.
Hopefully, you're still doing this next year, Chris. Not yet ready to rip out the radio and DIC, but I definitely want this done!
Same here. I've done all other conversions but don't have a heart to rip out the car at only 800 miles :serious
Quick question for the OP and/or Chris:
On the stock system, when you change through the different XM channels, it changes the background as well. Does this still happen post-conversion?
Also for Chris - Do you have any examples of the Blue Holden theme, or the Senator theme, and can the IPC be set to the same?
If the timer is like my C7 was. The bad part was when you took your foot off the brake the timer started it was not based on when you mashed the gas.
Its not THAT bad... I swear :)
I don't have pics of the other themes, I'm sure I could get them on there if someone REALLY wanted them but thus far no takers. The XM thing you can turn that off from the factory, still works that way its called XM art or something along those lines.
Thanks for the reply! That's good to know about the XM stuff.
I actually really like the blue theme and bluish lighting inside the car from the factory... Are you saying that you might be able to get those themes onto the IPC, or just that you might be able to get pics?
Update wise we should be just fine as long as the dealers follow the procedure LOL I will preface this that out of the hundreds (likely over a thousand now) modules we've programmed this has happened I believe twice but if it does all we ask for is a copy of the work order and we would redo it on the house. Most dealers are perfectly fine (especially with niche cars) that if you ask them not to screw with it they won't :)
For the record when the modules come in we DO update them to the VERY latest software before doing our changes.
Lurker here.
Will the Holden splash reprograming be available for the 2016 units?
I am unsure if there are any hardware and software changes for the 16's. I see via the forms that the CD was deleted, but I have not found any additional info on any MyLink hardware changes.
I am a little timid, as I see the bimodal settings are accessed via the MyLink display. I have no idea if MyLink is simply the interface, or if the settings live inside the unit itself.
Looking to do the full conversion.
RPG on order.
Supposedly my build week is slated for 12/21
Thanks for any info!
Welcome to the forum nnrd79a! Congrats on the 2016 RPG order!
Question for GTPPRIX... i read on here that you can also take a holden silver box and make them work on our chevy...is there any benefit to this over getting our chevy silver boxes converted to holden?maybe more read outs or options.
