Whos has heads and cam?
21K views 32 replies 21 participants last post by  14SS#4446
Hi
Some Like It Hot Red Metallic. Do you have a video?
Dyno numbers?
Thanks
#2 ·
Nobody
lets try this again
Heads & Cam installed,
Dyno #s are___________hp/ft
#3 ·
I have heads and cam. no dyno though
#11 ·
Thanks Russ! :)
#12 ·
I have just finished my mods with Heads,Cam tune. Roto-Fab, and full Kooks headers and exhaust. I am nowhere near 500RWHP with my setup. I have 1800 miles on the car as of now and my numbers came out at 460.8 RWHP and 430.0 TQ. Uncorrected numbers were about 10RWHP higher. I will have a post up later today showing the whole process. Car is extremely driveable and the cam is not overly aggressive.I will have dyno sheets with the post
Reactions: JCattSS
#15 ·
Thanks Andy. It's nice to hear that my numbers are normal. I also bet you'd agree that more would be available with an aggressive cam,but if you look at my cam spec posts you'll see we are speced with a S/C setup in our future,plus we are very drive able with a small(2800) converter
#17 ·
I've done various Cammed A6 LS3 cars that have dynoed from 450-510+ All depeends on Cam and Heads and Compression.
But dyno numbers are just that "numbers" Best thing is to see the before and after on the same dyno.
Reactions: pir4te01
#28 ·
@tryg I think it’s worthwhile at some point to consider how much faster / quicker a blown LS3 is over what you have now, down the 1/4, on street tyres. Both high 11s, all spin depends on baro and stuff for .2 delta right?
Then weigh that marginal difference when possibly, legally, applied to everyday driving on the street.
Go the 2300 conversion spend if you’re drag racing for no brainer mass energy burner. If you drive over a wide range of conditions everyday consider not turning your SS into a dragster at all.
Do you know the fastest time for NA SS with drag pack, stock stall and gears?
#29 ·
I have a stage 3 BT cam. I have a stall, long tube, cat delete, tune. Dyno 443 rwhp at the lsfestwest. Instagram is Lee_Bonneville.
