So last week I purchased a VCM OTR intake, for the VF, from a company here in the states. I like how it can almost pass for a factory option and it definitely feels like the car picked up some power from 4500 to 6500 rpm range. What do yall think?
Yes, this appears to address it. It was quite frustrating trying to convince them they had an issue for nearly 5 years though.
Yes, this is the same exact problem, it will allow unmetered air into the engine, causing it to run leaner than it should at idle, and part throttle, but richer than it should at WOT because it will carry over the learned fueling. So, not only can it develop a vacuum leak, but it actually can cause a drop in power, which is the exact opposite that you should want with performance mods :wink
Looks like the OTR's miss the mark on this detail...
"Ensure the MAF Sensor is mounted in the middle of a minimum 6 inch length of 4 inch diameter tube, and is a minimum of 10 inches from the throttle body."
https://www.chevrolet.com/content/d...d/02_pdfs/ls3-and-lc9-e-rod-crate-engine-control-system-40tooth-and-17tooth.pdf
Perhaps you are mistaken either about which pipe it is and / or where it connects on the intake. It is definitely not the same problem, PCV breather pipe vents before the MAF tube / throttle body, attached to the airbox plenum after the filter.
Nope, not mistaken.
The factory tube is on the silencer box, which is post MAF, and pre Throttle body. This is because the PCV system eventually allows air into the intake manifold, and this air needs to be metered as it's actually using that air for some of it's intake source. By putting that piece in front of the maf, you allow air to enter into the pcv system, and then it enters the intake manifold, causing the car to run lean.
Please, don't make the same mistake VCM did and fight us on this. It doesn't reflect well when a company doesn't understand how the intake system works, yet they manufacture one.
I chatted with Mace Engineering Group about buying this intake for mine. They did tell me that this intake would require a tune, and said I should look at buying the VCM if I didn't want to tune my SS.Ok I just want to clarify what you mean, not argue. There is some confusion here about PCV vacuum line, which on my car - L77 - looks like this:
PCV System.
Hose A-B
Fresh Air Supply Line.
From Air Intake Pipe to Front Right Valve Cover.
(Supplies fresh filtered air to the PCV system)
Hose C-D
Foul Air Line.
From Rear Left Valve Cover to Front Right Intake Manifold.
(Supplies foul oily air from the PCV orifice in the valve cover to the intake manifold for consumption by the engine)
If I understand your point correctly, the location of A is critical. Please illustrate or point to some research that explains why the air at A should be metered by the MAF?
Because the fresh filtered air at A has a critical effect on foul oily air entering the intake manifold at D?
I have no issue as mine is a full custom tune that compensates for such. I see that stock tune with unmetered air is an issue, yes.
However a MAFless OTR like the one above fitted with a MAF is not junk, fitted to the fastest Zetas in fact, just full custom tune (recommended) or fit the "A" coupler using a 90° nipple somewhere near post MAF / pre-throttle in the intake tube.
Truthfully, there isn't a way to calibrate it correctly since it's a mechanical variable.
in a big hammer approach, yes. However, since you are telling the maf that there is a hard amount of error, when it changes, the MAF never knows this, so let's say you back in 3%, but it's a cold, dense, high baro day and it's actually allowing in 7% more air, now it's only 4% off, but it's still off because of an issue.OK got what you are saying, thanks.
So recalibrating the MAF and commanding more fuel would not possibly overcome the lean issue?
