141 - 160 of 620 Posts
Id love that, but theres no one around me to do it. TuneTimePerformance has ignored me. Not sure I trust them anyway.
If a Dealer were to install this somehow, how would it get tuned?
Once mine is done, if I'm satisfied, I'll see if my guy can hook you up.
I bought the cheaper one. Still no idea what the difference was.
I didn't even look at 222...didn't know it existed...I got 235
Welcome to the forum NJ Torque!
What are you kids running for the vac lines/ports on the snout?
Mine had everything there...it was a take off from a ZL-1. For the brake booster, I bought one from GM...ZL-1
Fedge: can you post some pics on how you did this--for those of us who would like to do the same?
THX!
Haven't installed it yet, but I will! I'll also address any issues I didn't read about. I will say this: over the weekend, I removed the bumper cover and it's much easier to use a 2011-12 GT500 heat exchanger than the GM unit. You have to relocate the trans cooler to use a CTS-V HX and I just don't feel like doing all of that. The Afco for the 2003 Mustangs is wide, but might work...
I measured 28w X 5.5h X 3-4d available space with minimal modding (I'm cutting the plastic shroud from the lower grill)
has the wiring modification for the IAT been addressed? I didn't see it!
Doesn't the wire just get extended or something?
Thanks Fedge. This will be of great help to me and others who undertake this project. Always good to know IN ADVANCE what works and what doesn't. Again, pictures along the way will be appreciated!
Some notes based on my experience:
I used fuel rail 12605222 and found that the fuel rail adapter 22912576 would not fit without bending the stock hard fuel line quite a bit - much more than I wanted. I ended up just making a fuel line, not a big deal, each needs a GM 3/8" steel line adapter.
Also, the beauty cover comes with the rubber isolators so no need to order them; also there are 5 mounting studs for the beauty cover 11588406.
The CSTV EVAP line 12605523 is a tight fit, but it does work.
I haven't read the whole thread but definitely interested in the kit. I'm located in Houston and would like to know how much will the whole thing cost (including installation)?
Nice job!!
I've noticed that some people do not use the EVAP solenoid on the blower snout but it appears you did. Did you just extend the original EVAP tubing and harness from the stock location to the new solenoid on the blower? Is that how you used the CTS-V EVAP line for? Do you have any picts of the details on the EVAP line?
Also would you have more details on the fuel line that you fabricated?
Thanks.
I used the ZL1 evap solenoid and CTSV evap hose - it goes back to the firewall on the passenger's side. The wiring for the EVAP, MAP sensor and Throttle Body needs to be extended, and you have to pull the IAT wires out of the wiring to the MAF sensor if you want to use the temp sensor in the supercharger lid (a subject that can be endlessly debated).
For the fuel line, there are lots of options, I like Dorman 800-121 connectors Dorman Products - 800-121
and some flexible fuel injection pressure rated 3/8 hose. You need basically an "S" shape. The hard line at the firewall points out toward the driver's side and the fuel rail connection points straight back on the passenger's side.
Rao,
This is very helpful. Thank you! Other than getting a base tune to limp it to a tuner, I think all my questions are answered.....until I dive into it and have everything apart! :panic:
Reactions: Fedge378
I'm still gathering parts and pieces for this swap. Does anyone have the part number for the GT500 heat exchanger? Or, another suggestion (Afco?) for the HX ? The less butchery and relocation, the better...TIA
