Going to hardwire my dashcam. Which switched fuse is the best to tap into? Have a piggyback add-a-fuse.
I've purchased that same dash cam, worked like 3 times and it fried itself with the original charger...the company wants me to spend more money to ship it back to them to get a replacementI highly recommend the G1W-C. I had the predecessor, the DVR-207, and now this one. Great little budget dash cams.
https://forum.dashcamtalk.com/threa...te-review-of-g1w-c-capacitor-based-dash-camera-nt96650-ar0330-1080p-30fps.3543/
thanks, maybe I should spend the doughMy camera came with a hardwire kit to micro USB. Just like this one:
Amazon.com : Spy Tec Dash Camera Vehicle Hard Wire Kit - Micro USB Compatible with Mini 0806, Mini 0806 and Mini 0803 | Car DVR Camera Recorder Dashboard Dashcam | Black Box Video Recorder : Electronics
I powered mine via the dashboard fuse panel. I used an add-a-circuit on the positive end and grounded the negative. Since I wanted 24/7 power, I tapped into one of the shunts and used a 3 amp fuse for the camera. Regular fuse shown but ours are actually minis:
Ok so after a couple days with it powered on 24/7, I decided I'd rather have it hooked up with switched power. It turns out that all of the fuses in the dashboard panel are always on so I had to run power to the trunk fuse panel. Pretty easy to do cleanly. I hooked into the retained accessory power fuse. Since my camera mount has dual power inputs, I might run a 2nd hardwire kit to the front fuse panel and leave it unplugged at the mount in case I ever want to temporarily have full-time power.
I can confirm this as well. I've had my detector plugged in for several weeks now and in the mornings it's off. Battery is fine as well.The above is how i've powered up all my detectors. I too was looking for a key-on power source in dash fusepanel. As Kannon mentioned, all were constant power there. In the interim I kept it there and just powered the detector down at night down...
All that said, I have forgotten to turn it off several times now to come out and find the device off in AM. So the source i'm using might just remain on for a period of time after car is locked... Ideally i'd want it to power back up upon starting, so will have to run to engine bay or trunk fusepanel, but I was mostly surprised by the delayed power i tapped. If anyone else can confirm their does this too, i forget which fuse i finally decided on as I tried a handful.
I'm using 3 amp fuses on my Power Magic Pro. Fuse taps using constant power from fuse box on left side of dash and switched power from fuse box near battery in rear.I have the BlackVue 650s-2ch camera on my 2015 SS. I hardwired it with the Power Magic Pro box. I used a fuse tap for Batt and ACC power in the trunk and don't have issues with it except for the remote start does not work, I'm thinking I'm using too small of an amp fuse (3 amp).
My question is, for those that have the BlackVue cam, what size amp fuse did you use for the camera using the fuse tap?
warranty expired ???Update on my issue with remote start. It was completely NOT related to the selected fuse spots I chose for my camera setup. It was a defective hood latch sensor making the car (BCM) think my hood was open. Dealer wanted $140 for part plus labor; I paid $53 and installed it myself.
