21 - 26 of 26 Posts
Final tightening of suspension components should be done with the vehicle sitting at normal ride height.
Well dang it. I did not
Question please: I’m getting ready to install the end links. I see in the instructions to install them at curb height. Should I install them when the car is back on the ground? New to installing suspension items. Thank you
Yes, car on the ground.
Reactions: anomadtoo
Discussion Starter · #24 ·
not the end of the world - what links did you end up using (this is the Whiteline non-adjust bar?)?
What would REALLY be the "right" way is to find some car scales (race car setup scales), check the corner weights with the links disconnected, then attach the links and do the best you can to NOT change corner weights when the links are attached and tightened.
Yes the Whiteline non-adjustable bar; I used the MOOG end links. They are actually really nice, I’m glad I went with them (thanks for the suggestion). Even when I do lower the car I don’t see being able to reach behind the wheel and tighten everything; and now being on King lowering springs.
The sway bar and end links are not necessary to tighten at ride height. Everything else should be though.
21 - 26 of 26 Posts
