1 - 11 of 11 Posts
It POURED here in South Florida for the first time since purchasing my 2017 SS a month ago. Got in today to run some errands and noticed both A pillars were wet. Sunroof drains appeared to be free of debris but to be safe I blew them out and poured water down them and they do indeed drain to the floor. Anything else I should be checking for?
(Pic of track just to show how clean and new everything is. Car only has 3k miles)
If it has had a windshield replacement,,, then my wager is that it was NOT installed and sealed properly!! Perhaps the tech did NOT properly clean out,,, ALL of the old sealant,, and prep the clean surface prior to applying a new bead!! That would be my first thought on this!!!
Good Luck!!
:unsure:
Also keep in mind the airbags that lie within those a-pillar covers. If you attempt to do any water tests, I would disconnect the battery at the very least.
Do you hear creaking while driving
If so the windshield wasn't installed properly. Is it delaminating?
Check all the seals on the sunroof surround. But my guess is likely the windshield leaks...and I hope I am wrong.
Another vote for the windshield. Although my windshield was original, it was not properly sealed at the factory. I didn't get any leaks but I did have that annoying creaking sound. Had the windshield removed and re-sealed and all has been good, zero creaking noises.
Discussion Starter · #8 ·
Windshield not sealed factory seals have been know to come loose allowing in water and making noise
The car is very quiet at highway speed, no wind noise or creaks. Going to grab a friend this weekend and soak each area individually with a hose and try and pinpoint the issue. Hope the issue is gone now that I blew out the drains. FINGERS CROSSED.
Herbie,
have you figured this out?
1 - 11 of 11 Posts
