1 - 20 of 33 Posts
This SS of mine is a really fine car but unfortunately the one I bought has so many creeks and rattles that I find myself so disgusted with it and thinking about what options I have to rid myself of this frustration. I will take it to the dealer Monday and leave it until they can find and fix the issues. Wish me luck!
Holdens are normally of good quality, but its what ive said before, its never good to buy a car when the manufacturing plant is closing, whether it be BMW or any other manufacturer. I wouldnt be surprised if your car was made after GM made the announcement to close Holden.
I know you have posted about the issues before, has the dealer been able to find anything or has it been to the dealer for these issues yet?
Do you have a brief description in a post that I missed? Would like to read over it. To say it has a rattle where and creaks and so forth.
Ask GM Customer Care (here on the board) to help you so they can inform your dealer of your issues..Then there is a log/history from you, the dealer and GM Customer Care of your issues should things not get fixed..
· Banned
Mine has a few rattles as well. There is a small one in the driver side door and a small one in the passenger front door. I think I have pin pointed it. But, I just turn the radio up louder, then, the stupid speaker grill on the passenger front door rattles on certain bass notes.... smh...
Reactions: G8GT214SS
Sometimes when I have the cruise control set to 63mph and I'm listening to AM radio, on channel 102.1, with the climate control set at 77 degrees Fahrenheit I see unicorns running across my hood.
Foreal though, it is so hard coming into a dealer and trying to explain the issue and portray how really unhappy you are with it. I'm sorry bro. that just sux.
Are the shipping blocks still in your front springs???? Have the tire pressures been lowered down from the shipping pressure of 50 PSI down to 36 PSI???? My car is silent going down the road except for passengers screaming for more!!!!
My Firehawk(yes, I know it is a completely different car) did that as well, and of couse it had T tops. The point I'm making is, there may not be much that the dealer can do about it that you would want them to do. I fixed mine by installing subframe connectors( a popular fix for that problem on an F body), however, I worked at a Cadillac dealer and one of my customers had a similar issue with an early CTS we had to cut holes all throut the right rear of the car looking for broken spot welds!!! I don't know about you, but I wouldn't stand still for that.
Just make sure that you and the dealer can identify the noise as a problem before the work starts.
I'm a heavy metal fan, lots of double bass and so on. I hit 45 most every day. Not one time have I heard any sound, other than music,from the car or speakers. I have heard the amp clipping and turned it down just under the threshold. Sounds like your speaker bolts may have come loose.
Hey G8GT214SS,
I am sorry to hear you are not happy with your SS. I would like to look further into this for you. From the other posts here it seems as if you are not located in the United States. If not, please private message me your location so I can provide you with the correct information. Hope to hear from you soon.
Erica Tiffany
Chevrolet Customer Care
http://www.ssforums.com/forum/members/g8gt214ss.html
I had the same thing on the drivers door. The guy at the dealership just ponded on the door panel and some loose clip locked in place, made a click while doing so (just like when you attach door panels). Rattle stopped. Try pushing the door panel in with moderate force, it might help.
Sounds like the guy on the door panel line wasn't using enough pressure to mount the panel.
If your AM radio hits 102.1 MHz, that is probably what attracts the unicorns!
Sent from AutoGuide.com Free App
Discussion Starter · #16 ·
I will take and leave it Monday to the dealer and hope that they are able to find and fix. And yes, I have tried the increase the volume of the radio option but as someone else correctly pointed out, then the doors rattle and vibrate from the base. I've never had so much trouble with a new car. I dread taking it in. Luckily, I will have a loaner. Thanks everyone for your support and feedback. Will keep you posted.
1 - 20 of 33 Posts
