1 - 9 of 9 Posts
I am installing some parts on my car, and need to get the hose off that either to or from the tank to the purge solenoid up by the Throttle body. its a black hose with some sort of yellow mechanism.
How do you get that hose off? I am getting flustered with it and fear II will break it soon. There are actually 2 of them, one by the firewall and one by the throttlebody.
Please help!!!! I am stuck...
Arm Automotive tire Motor vehicle Automotive design Gas
Automotive tire Hood Motor vehicle Bumper Tread
There should be a another yellow tab piece on the opposite side. Squease the two together and pull the hose off.
I think,...if I remember correctly!
Discussion Starter · #5 ·
I will try that again. by "tabs" you mean the rectangular yellow ribbed-looking ones? or do you mean the smaller, square, sot or recessed yellow things 90 degrees off from the bigger rectangular ones?
I have squeezed, pressed, pulled, pushed, etc my fingers bloody, but I will go try again.
THANKS for the responses!!!!
Push it in first, then squeeze and pull.
I have done this a few times and sometimes they are a little bitchey to get off.
Discussion Starter · #9 ·
Hi all thx for the help. The fitting near the firewall came off exactly as you guys described.
The one up front absolutely refused. it was as though it had been filled with epoxy or something.
It met an early demise... I am back on track.
thx again!
1 - 9 of 9 Posts
