1 - 17 of 17 Posts
Anyone here track their SS? I am looking for any info on brake pad upgrades as well as recommended brake fluid upgrades. Not going to get crazy out there. Just want to be safe. Thanks for any info!
As long as your stock brake pads are 1/2 thickness or more, and you have had a thorough brake flush done with a high boiling point synthetic fluid within the last year (six months more preferable); AND your pads have been bedded according to the trusty owners' manual, your brakes are more ready for track duty than you might expect. I change the color on every brake fluid flush so we can tell all the old stuff is out of the system.
When and if you get serious about tracking for hours on end, your brakes may be ready for pad and fluid upgrades.
And DO NOT set your parking brake after your run group finishes. You want the brake pads to be able to get away from the potentially hot rotors; setting the parking brake does not allow the pad to relax away from the rotor. And I do not apologize if this sounds like the ridiculous term "man splaining".
There are several track day threads.
..."And DO NOT set your parking brake after your run group finishes. You want the brake pads to be able to get away from the potentially hot rotors; setting the parking brake does not allow the pad to relax away from the rotor."...
Biggest concern is warping rotors.
Along with not setting the brakes, my instructor taught me to make a couple circles around the paddock to let things cool down before parking.
Well, if we're really going to get into the mansplaining . . . I always understood it to be necessary to prevent uneven pad transfer, which leads to "judder", which most people misinterpret as warped rotors. :wink
With fixed calipers you are not likely to have uneven pad retraction (assuming that's what you mean). But either way, once the brakes are applied, the pads are clamping the rotor with equal load, unless one of the pistons (in a fixed caliper) or the caliper itself (if floating design) is stuck. The "judder' can come from geometry (warp) or friction (rotor surface roughness) variation. Judder from friction/roughness variation usually goes away after a few brakes, but not if the rotor gets warped.
Nope, that was not what I meant at all. I was simply referring to the fact that leaving the pads clamped to a just-off-the-track HOT rotor while stationary will cause excess pad material to be deposited at that location on the rotor.
I disagree that the buildup of deposits on a rotor (causing thickness variations) that are felt as "judder" will usually go away after a few brakes.
This is all completely separate from actual warping of the rotors.
I have not experienced pad deposits on rotors so cannot comment. I did experience (unfortunately) rotor warping and learned my lesson...
Cheers!
Reactions: Gangreen16SS!
Live and learn, I guess! Thanks for the education!
Is an "upgraded" brake fluid really required? These cars don't come with brake fluid that is capable of you tracking the car?
If you are going to track the car you want fresh brake fluid, not one that accumulated moisture over months or years, so you will want to replace the fluid regardless.
I don't track this car (yet), but in my track cars I've always used ATE racing fluid and replaced it before each event (alternating blue and yellow). Also switched to racing pads.
Both in an effort to reduce the occurrence of agricultural excursions due to pedal dropping to the floor (fluid boiling) or pedal staying hard but no braking (pads glazing).
These are among the smallest expenses associated with tracking, but they buy piece of mind and help prevent loss of track time or worse.
Reactions: LAG and jimster480
I see. Noted; as I plan to track the car sometime this year.
Sent from my HTC 10 on Sprint using Tapatalk
There are "track days" and there are High Performance Drivers' Education (HPDE) events, and there are car control clinics.
If you are a newbie, and I think most questions here are posted by newbies, your car left the factory ready for anything you are going to throw at it for HPDE and/or car control clinics. Your brake system absolutely need to be equipped with plenty of brake pad thickness, with brake fluid which is not older than a year (brand new is best), the factory seat belts for driver and instructor need to be in excellent condition, and your tire condition and air pressures want to be correct. And your lug nut torque should be correct.
By the way, in my mind "track" means something different from eighth mile or quarter mile straight line events.
For HPDE events and for Car Control clinics I think most people obsess about prepping the car rather than prepping the driver. HPDE events will likely have you and your car on track for three to five sessions of 20 -30 minutes with an instructor aboard for newbies.
Car control clinics you will usually be involved in lots of slow speed maneuvering in such things as skid pad work, both dry track and wet track. You will likely be doing lots of slalom work, and MAYBE a full autocross course. Most of those events are going to have speeds no higher than highway and back road speeds, with little heavy brake work. Some events, depending on where they are held, may include a few laps on a race track with an instructor along side.
HPDE events will have you in some sort of track environment ,on track with an instructor in your car On HPDE events you will be going at speeds higher than normal highway speeds, and you will be using your brakes hard, in order to get down to safe cornering speeds. Your brakes will get hot. They will not get racing hot in any run group which has you required you to run with an instructor. Relax about brakes, focus on what is inside your helmet.
Once you get a few days behind you and move into run groups with no instruction your car may be ready for mechanical upgrades. Now you are getting to track days.
PLEASE NOTE (my opinion follows):
If you are indeed a newbie, stay away from events like Sports Car Club of America{(SCCA} "Track Night in America". You and other drivers on the track at the same time as you are not experienced, and with no in-car instruction, participation is neither smart nor safe. You will learn nothing about correct hand position, accelerating technique, MIRROR monitoring, braking, MIRROR monitoring, turning....nobody is going to be watching your eyes, and where they are focused as you are on track, or in the pits.
Some events will sometimes have fewer instructors and start of with "lead-follow" laps, where newbies follow an experienced leader, and track side potters can see who is doing what in the formation. Never done one of those, have no experience.
Moved to Track Day forum as that is the direction the thread has evolved.
1 - 17 of 17 Posts
