81 - 100 of 402 Posts
Does anyone know if Konig Glide 18x8 rims will clear the brakes on a 2016 ss sedan? Thinking about winter setups.
Sent from my SM-N920P using Tapatalk
Discussion Starter #89
29mm
Here's all the info from TireRack:
Offset:29mm
Backspacing:5.63"
Bolt Pattern:5-120
Rec. Tire Size:245/45-18
Weight:28.0 lbs.
Finish:Black Painted
Construction:1pc. Gravity Cast
Finish Warranty:2 Year
Manufacturer Part #:W1916000553
Manufactured in:China
Discussion Starter #91
29mm
Offset:29mm
Backspacing:5.63"
Bolt Pattern:5-120
Weight:28.0 lbs.
Thanks! Post #2 updated (winter setups).
I don't think these have been posted... just picked them up a couple days ago. OZ Leggera HLT. The rears have a bit more dish than the front and really accentuates the staggered stance without requiring a lip. Works really well I think. ...yes I have Eibachs on order. :lol:
Leggera HLT - OZ Racing
19x8.5 et35
19x9.5 et45
Stock tire sizes
Hello all! New to the forum with our new 2016 SS.
We are currently reviewing the "Winter Wheels/Tires" and have a couple questions.
First is on the information provided in "post #2 - Winter Setups". For example on the following information: "Front: 18x8 +30 (0.46 out) 26.0 lb"
I understand the 18x8, but what do the "+30" and ".46 out" mean? Assuming the 26.0 is air pressure.
Thanks,
FNG
Thanks,
FNG
Figured out 26lbs is rim weight.
Depends on the offset and the shape of the spokes on the inside of the wheel.
When going with 18" wheels you really have to start worrying about caliper clearance.
If you're getting this package through Tire Rack, they guarantee the fitment since they do all the homework.
Perhaps I missed it but anyone running VRM V810s in the following sizes.
Front 19x8.5 +35 or +45? Wondering if the +45s clear the calipers.
Rear 19x9.5 +58. Again do they clear the calipers?
This setup may be good for lowering and minimize rolling or cutting.
Front +35 vs stock
Front +45 vs stock
Rear +58 vs stock
Edit: I think I found my answers in this thread in the G8 board but would still like to know if any SSs are running this setup.
New Wheels Installed!!! VMR v810s
https://r.tapatalk.com/shareLink?url=http://www.g8board.com/forums/showthread.php?t=144249&share_tid=144249&share_fid=90751&share_type=t
