Yes..Defin Brembo's like HARD Stops...I did that very thing and they stop sqeaking..The thing you need to remember with the Brembo's is, don't baby them. If you use light pressure with them they will get glazed and squeal. If they get bad, do a couple hard stops, to knock the glaze off.
Armourall has a spray product some folks on corvette forum use.I have the same issue, but I noticed that I get break dust on the inside/outside of the rims quite often. Cleaning them regularly. The squeeking, as slingshot, toofastss and 1badss said, stopped if the Brembo's aren't babied. Has anybody found a good rim wax that keeps the break dust off?
Addressed here - by bulletinMy front brakes squeak occasionally. Only at low speeds. I had had this issue with Brembos before on a Lancia Integrale I had but I did not expect it on the SS. Is anyone else having this issue?
Do they seem to be wearing quick since they dust so much?All..I had the sqeaky brake issue in the beginning (first 750 miles) but after several here on the Forum saying to apply serious pressure and use the Brembos like they are intended; after approx 500 additional miles that all went away..The only time now is when I've used them hard in traffic on a hot day but I keep in mind this is how performance brakes sound! Like others say just drive the car and use the brakes as they sure work good!..(I do notice though serious amounts of brake dust but that too is common for performance brakes!)..
