side Black Out Window Trim Done!
15551 Views 23 Replies 13 Participants Last post by  joshua
full Black side trim is now done! the top window trim was cake. the lower Trim... no so much!
now the door handles look out of place. i tired to remove these but they are NOT removed like the G8 ones. at least there is not a standard bolt that removes the handle. it is a torx bit and it looks totally different in the inside. i am a tad weary of removing it that way and think it might be better just to remove the door panel.
21 - 24 of 24 Posts
funny I checked the part # for door moldings and black rear ones are available in USA but the front ones are not
i have been debating that. personally i think black wheels just look black. even if they are aftermarket wheels... they just look well... look black... moving, they just look... black.... daytime... they look black. i think you get my point. AND i know, i own a set on one of my other cars.
however i have been looking at these Forged VOLKS
here is black:
and they don't look that bad on it.
and in sliver
i am going to have these test fitted within the next few weeks to see if i can get these to work. problem is the offsets on these wheels is this:
RAYS WHEELS
in a 20 incher the offsets i think are pushing the limits.. what do you think?
i may end up going with a 3 peice wheel but i would rather have a monoblock forged wheel.
what do you think about those offsets? i think with you being overseas you prabably can find more info about aftermarket wheels offsets on the VF.
i also will be lowering this car as well so i have to consider the offsets very carefully. the car is going in for test fitting this month for coilovers so i'll know more about that later too. ;)
Nice. Are those G25's? I have been looking at those and TE37's. How did you get the picture with the SS and different wheels? Is there a configurator available?
Does anyone have part numbers for the 4 uppers? My mom works for GM and can get them at cost. I would think that will be much cheaper for me then getting it from AU. I allways try and get part numbers for the parts guy if I can.
i actually should have some of these in the next week or so if you are interested.
yes they are. i actually photoshopped those. i was going with those and had them on order but i ended up going with GramLight G0FXXs
and then changed them to Forged Yokohama F50s
if you are looking for these wheels i am a distributor for these but know all RAYS wheels are usually made to order. sometime they have them in stock.
Wow! Hands down my favorite SS on these forums.
21 - 24 of 24 Posts
