1 - 7 of 7 Posts
I am having the Shift into Park message show up. Even though it's already in Park. So, then The car won't lock or the electronics won't shut off either. any advice on a fix would be appreciated. otherwise, it's off to the dealership. thanks.
The switch attached to the shifter.
This is common on other GM cars, Camaros and such, even my SRX, never seen it on an SS. Usually requires the replacement of the shifter, but, if the switch can be obtained or cleaned internally, that would take care of it.
This is for a 2016+ Malibu, but the microswitch looks to be the same in many GM vehicles. It would appear that bending the microswitch tab for a more positive engagement of the switch may work, although GM recommends shifter replacement.
2015 Chevy SS, Auto, Sunroof and Spare
Wow thats crappy. Curious have you spilt anything in the center console recently? I would say the microswitch is your problem but you be surprised what can happen when liquid gets where it doesn't belong. My gf spilled her coffee one morning in her charger and it ended up requiring the replacement of her shifter and some.module.
Discussion Starter · #5 ·
Nothing was spilled. i try to limit my drinking of beverages. but, thanks for your comment. I'm going to look into the microswitch though.
Discussion Starter · #6 ·
Thank you for the video. It helped a ton. For the 2014 Chevy SS. The micro switch is on the driver's side of the shifter. But I followed the guy's suggestions and it's working just fine now. Thanks again for the help.
Good to hear! (y)
1 - 7 of 7 Posts
