1 - 6 of 6 Posts
So I got my Solo bolt in cat but, I would really like to see you offer a secondary cat pipe. Probably a straight through pipe sans cat. then I could select a cat back if I chose to do so
I don't think thos are cats, if the is no o2 sensor after it then it's not a cat. But what do I know, only that the 16-17's don't have them nor the resonators.
Mine is a 16 and I don't have the center resonator but I do have what some refer to as a secondary cat/ resonator. I do know that GM has had 4 cats for many products though. And, you are right there are no O2 sensors on them. GM parts direct diagram shows the 4 items but calls the front ones as catalytic converters and the rears as just converters. So I am going to cut them out regardless. I was really just looking for a stainless pipe replacement
I just had these cut out and replaced with pipe. They are indeed cats. Secondary cats never have O2 sensors
Good to know, thanks for the correction.
On the 14's the flange is between the 1st and second cat. When putting a fresh cat back on, it eliminates the secondary cat.
Reactions: snoot
1 - 6 of 6 Posts
