There are many factors to consider on dyno results. Here are just some of them. Was this dyon'd the same day? on the same dyno without removing the car? Mustang Dyno's are notoriously inaccurate because every data item has to be input manually which leaves much room for user error. Another note is where was the wideband located? This can impact how it reads. What type of fuel was the wideband calibrated for? using a/f ratios are very inaccurate for tuning as optimal a/f ratios vary based on chemical composure of the fuel. The optimal A/F of 100% gasoline will be different than E5 E10 or E15, and have other varying factors impacting this but placement of the o2 can have a profound impact on reading.
Another question is do you have 91 octane, or 93? We ahve 93 in our area so all the gains we advertise are for 93, with 91 being slightly less. We do see a similar delta typically, but the conditions of the baseline can play a huge part in numers as well. What was coolant temp? oil temp? intake air temp? All of these can effect the results. We make certain we do our best to show a true apples to apples comparison on our dyno results, making certain it's within a certain acceptable window of variance. This is why many times we don't post our best results as they may be skewed due to slightly lower temp readings.
