i looked under the fuse/relay box and i could not find which one was for the blinkers/turn signals. maybe i am blind or cannot read (which can be the case sometimes) but i don't see one. anyone know?
correctHe probably installed LEDs in his turn signals and needs to change it out to a relay that won't cause hyperflashing.
It may not have a separate relay for the flasher or even a flasher can. The flasher is probably just a chip on the circuit board in the instrument cluster - that is how are Falcons are so I wouldn't be surprised. I will make a call and find out tomorrow if I get a chance..
thanks guys. well that idea is gone. the way these bulbs connect also also prevents you from easily putting in a resistor in as well. oh well.BCM controls most things so I bet the BCM has the flasher relay built in.
I'll check
Edit:
Yes the BCM holds the relay for the turn signals
If only someone or there knew how to custom program the bcm....thanks guys. well that idea is gone. the way these bulbs connect also also prevents you from easily putting in a resistor in as well. oh well.
You should fly out to Florida and program my car. I don't want to pull out the cluster, HUD, radio, etc from it and ship them out.If only someone or there knew how to custom program the bcm....
and only if there would be someone whom actually replied back to emails.If only someone or there knew how to custom program the bcm....
