I need to correct mis-drilled license plate mounting holes that were made in the rear valence. Holes are about 1/4" - 3/8" difference in mounting height. Had to file out the holes in the plate to get it straight and now it's time to do a permanent repair so I can mount the plates with some frames. The only good way I can see is to to add some reinforcement on the back side if there is room -- like aluminum or steel bar? -- and drill/tap for machine screws. How difficult is it to remove the valence? Will I need any replacement fasteners or other parts to reinstall? Any other ideas for a solution?
