1 - 20 of 33 Posts
So I drove about 15 miles with 2 16oz water bottles in the rear cup holder.
290294
Bad idea I guess, as this resulted in the bottom of the cup holder falling off. The bottom part still seems to be intact. Can anyone tell me how to remove the unit from the rear seat bottom to attempt a repair? I can't see it well enough where it is to really tell if it came apart or broke. Thanks.
How'd you get a rear cupholder???
290300
Thanks 15SuperSport. I tried gently, didn't want to go harder as I thought I might need to insert something somewhere. I'll give it a better pull.
We're still talking about your cupholder, right? ;)
Discussion Starter · #8 ·
Haha. Tried it, but no luck, could feel the two lower clips release, but even with small pry bars it won't let go of the seat. Afraid I'll damage the seat if I push on it harder. The pulllout stilll works, guess the new bottom will be the carpet.
Not sure if it is accessible from underneath, but I believe the seat bottom to be an easy out. Otherwise, your cupholder probably became much sturdier and able to hold larger, heavier, non-staining sugar free drinks... :)
You know those big bottles fit in the front doors, it leans outward.
I would take a picture, but,...
You might try reaching out to member @CB750 . I think he may have swapped seat bottoms when he traded in for a VFII, he can probably tell you if you can get at it from underneath. That may have just been a wheel swap however, my memory ain't so good... :unsure:
Reactions: ESindon
This is a common GM cartridge for the rear seat used across other vehicles [i own 2 others with the same ones].
You can get to it under the seat if you pull the bottom out, sometimes it is easier to see the retainers
I have one loose somewhere i'll see if i can find it.
These break a lot. My friends kid has broken 3 now.
Now I want a 2014 rear seat just for the weird ancient cupholder in it.
If I still had my '14, I'd probably modify the slot with my daughter grown and on her own. I'm thinking that it would be a sweet spot to put a quick release gun drawer. (y)
Y’all shoulda just asked me lol.
Anyway, grab the bottom cushion about midway on the driver then passenger side giving it a good yank
Once you flip the cushion over, extend the cup holder, then locate these two retaining tabs
Push them in, and pull out the assembly.
Once you have it on the bench, take a small screwdriver or prying tool and gently release the 9 retaining tabs around the sides and rear.
That should give you enough access to the sides where the lower part attaches
Hope that helps. I did this on the fly as I made this post, which was about 10 minutes, with pauses for pics and typing
And that’s it all put back together.
Discussion Starter · #19 ·
Thanks Mr Monte for the video and Fedge378 for all the pics and write up. Look easy enough. I'll give it a shot this weekend.
Discussion Starter · #20 ·
MIEngineer Thanks for the info. Nice to know it won't be a hard to find discontinued part.
1 - 20 of 33 Posts
