Might be mechanical. Springs, trunnions, and even worse. Lifters. In my case it was a lifter.
I should probably note that the first 10 min of driving this morning it ran without a misfire but it ran sloppy. After 10 min it was a constant misfire.Might be mechanical. Springs, trunnions, and even worse. Lifters. In my case it was a lifter.
Why does mine affect sometimes all the cylinders and sometimes 3/5 and 5/7?I too am a member of the bad lifter taking out a cam lobe club. Stock lifter and cam lobe. Looked identical to that pic. The noise was a giveaway for me. I also had a misfire from a bad injector before but it sounds like you addressed that already. The lifter was weird. Sometimes it ran perfect. Other times terrible.
Always good to hear good news. Happy holiday!Swapped the bank 1 sensor with new one already, found the issue to be a bad ground being the head. It broke flush with the bolt and the shop who did the trans ziptied it so I couldn’t see the wiring. Found it and fixed it, back there normal.
Hey where was that wire located? I'm having the same issue and when through all the same checks except this oneSwapped the bank 1 sensor with new one already, found the issue to be a bad ground being the head. It broke flush with the bolt and the shop who did the trans ziptied it so I couldn’t see the wiring. Found it and fixed it, back there normal.
