VCM intake, Rick Crawford intake and tune, hi flow cats. Maybe a cat back exhaust.
I'm still wondering if I even want an LT1. I'm turned off by it having Displacement On Demand and variable timing. If it was simply the LS3 reconfigured with direct injection, I'd be all for it. The experience in the G8 community is that the DOD is a weak link in an otherwise solid engine. The first thing that I would do to the LT1 would be to swap in a DOD delete kit.If the SS had come with the LT1 (or if it does next year), is there any aftermarket support yet?
Will the vcm fit?VCM intake, Rick Crawford intake and tune, hi flow cats. Maybe a cat back exhaust.
The AFM lifters are the weakest link tbs .... randomly my Yukon will sound like a hammering beast. The only way to stop it (restarting or driving doesn't help) is to goose it over 3K to get a surge of oil pressure and uncollaspe them. The two on the pass side are the usual culprits but the drivers side messes with my head occasionally.I'm still wondering if I even want an LT1. I'm turned off by it having Displacement On Demand and variable timing. If it was simply the LS3 reconfigured with direct injection, I'd be all for it. The experience in the G8 community is that the DOD is a weak link in an otherwise solid engine. The first thing that I would do to the LT1 would be to swap in a DOD delete kit.
Likely it may have used the same ECM that is in the Corvette, so chances are tuning would have been an option early on.If the SS had come with the LT1 (or if it does next year), is there any aftermarket support yet?
you can do that? LOL shows how much i know, how simple/expensive is it? TBH seems like a must have mod if your fuel efficiency indifferent...I'm still wondering if I even want an LT1. I'm turned off by it having Displacement On Demand and variable timing. If it was simply the LS3 reconfigured with direct injection, I'd be all for it. The experience in the G8 community is that the DOD is a weak link in an otherwise solid engine. The first thing that I would do to the LT1 would be to swap in a DOD delete kit.
My G8 GT came with AFM/DOD and I swapped it out with non-DOD hardware so that it's more similar to the LS2/LS3 setup. I think a lot of the camaro SS guys are swapping out their DOD and their variable valve timing, but I'm not as familiar with what all is required to ditch the variable timing. As for the DOD delete, there are various kits out there, but they are all primarily GM parts that you use to swap out the hardware with prices ranging from $500 to roughly $1400 depending on who you buy it from and what parts it comes with. I did the install myself so I saved a bunch of $$ on that piece so labor will cost you a bit.you can do that? LOL shows how much i know, how simple/expensive is it? TBH seems like a must have mod if your fuel efficiency indifferent...
Livernois stage 1, but am considering pulling it again for a Lunati grind that's supposed to be a pretty sweet setup, but am going to do some more research before doing anything. If you're looking for a strong cam with just a tad bit of lope and really good street manners, the Livernois stage 1C is a nice one too. The stage 1 that I have has some lope to it and is just about as big as you want to go without adding a stall converter.I'm soooo looking forward to doing a DOD delete to my G8 GT. What cam did you go with? G8 GT V8
