Anyone else have a problem with a creaking sound when doing tight turns (like in a parking lot)?
I had the same problem. It didn't show up until it got wet.I did, turned out I had a shipping rubber in the left front spring they did not remove. Removed it and no more creaking. Might be something to check.
Same here, started hearing weird creaking noises when I turned the wheel to the max, found out they left the red shipping blocks on the springs. Once removed, everything was fine.I did, turned out I had a shipping rubber in the left front spring they did not remove. Removed it and no more creaking. Might be something to check.
Welcome to the forum TheSlacker! Give us some more details about you and your new ride. :wink:Anyone else have a problem with a creaking sound when doing tight turns (like in a parking lot)?
Yes, they are in the front springs and pretty hard to miss! And check this link if you haven't already, page 4 has a pic:I've noticed creaking at times when I make sharp turn at slow speed.
Would I be able to see the shipping blocks by turning the steering wheel fully and looking through the wheel wells?
No blocks in the rear but they did ship with rear rotor covers. Those are pretty much always removed before delivery though.Problem solved. There were red shipping blocks in the front suspension. Calling the dealer in the morning. Are there also blocks in the rear?
No, in the rear there are only plastic brake disc covers.Problem solved. There were red shipping blocks in the front suspension. Calling the dealer in the morning. Are there also blocks in the rear?
