WHAT!!!! SAY IT AINT SO!!!
GIVING THE RONA TO THAT POOR UNSUSPECTING SS!!! SHAME ON YOU FOR NOT FORCING IT WEAR ONE OF THESE,,,,,
Great job! glad you are back...Btw I did all this while having rona!
waiting for parts to complete it.
Yes it being upside down irks me. I already fixed it also wired and mounted the pump relay kit with RIVNUTS!!I took my newera decal off but it was on correctly unlike that one. I also trimmed the bottom of the tube a inch or two to get the filter off the belly pan. Looks like it’s all coming together now! Good Work
I’ll do that later. It’s just a matter of running 12v to the trigger wire on the relay. I’m actually trying to find socket end for a wire to fit in the fuse block connector. 48 is the location where my finger is in the picture below. Goes between the striped green and purple. I want the female pin that goes on the wire to fit that connector. Then all I have to do is put a fuse in the panel.While you have everything apart still, put a manual switch on the HX pump. You'll thank me later...
I “t”d mine into the radiator overflow line. I run the same coolant mixture in both.So I have a question...
To the people that have used the cobalt res degas tank, where did you plumb the top port to? Magnuson uses the same one yet they let it vent to atmosphere behind the headlight but that seems strange to me.
What fitting did you use? The degas bottle is way bigger than the hose for the overflow.I “t”d mine into the radiator overflow line. I run the same coolant mixture in both.
Vent to atmosphere is normal for a pressure relief cap .. It will only spit if your coolant boils over and exceeds the cap rating.So I have a question...
Did that with a fan switch once.While you have everything apart still, put a manual switch on the HX pump. You'll thank me later...
That’s what it’s doing nowVent to atmosphere is normal for a pressure relief cap .. It will only spit if your coolant boils over and exceeds the cap rating.
