LSA Supercharger conversion parts list
397K views 619 replies 121 participants last post by  716SS
#1 · (Edited by Moderator)
LSA Supercharger conversion parts list UPDATED
I've been eyeing a thread on the g8boards where there have been numerous people doing this swap with relative ease and for extremely inexpensive. Being that I work behind a GM parts counter I decided to see what all the parts would cost new and I took some information from the g8board and compiled some of my own research and I put together a parts list with part numbers. Note that not all the parts can be purchased from a GM parts supplier or parts counter. There will be some parts that you need to purchase after market.
19303635 - Supercharger w/snout and pulley
12622236 - ZL1 Lid with bolts, sensors, IC, seals, fittings for IC hoses
12639188 - EVAP solenoid
12603916 - Balancer (crank pulley)
12557840 - Balancer Bolt (x1)
12606501 - Idler Bracket
11588727 - Idler Bracket bolts (x3)
12606031 - Idler Pulley
11518630 - Idler Pulley Bolts (x2)
11900254 - Idler Bracket bolt (x1)
12606032 - Idler Pulley
12606500 - Tensioner Bracket
11588749 - Tensioner Bracket Bolt (x2)
11588742 - Tensioner Bracket Bolt (x1)
12622452 - SC Tensioner
11588753 - Tensioner Bolt (x1)
12636227 - Stock SC belt for stock pulley sizes
22879421 - ZL1 Heat Exchanger
19180613 - LSA Intake manifold gaskets
12612467 - IC insulator
11588718 - Supercharger bolts (x10)
12622235 - Fuel Rail
12598646 - LSA Injectors (x8)
22912576 - LSA fuel line adapter ($33)
Bosch IC pump 92.50 on Amazon
IC pump harness w/ relay from Magnuson $45
The above parts list is almost everything you will need to complete the kit and our employee pricing has all of the above priced at a tab of $3392.80 not including the Bosch IC pump, not including the ZL1 Heat Exchanger (the gm IC pump is way too expensive so I wont even list it), and not including tax or shipping where applicable. I am at a new dealership now and can do a lot better on the price of parts.
If there is enough interest in this I can put this together as a kit and sell as a package. We are working on doing some customization to new vehicles and the owner of our dealership is working on getting on board with offering this as a kit that we can sell and install for customers.
Note All parts listed above are from a 2014 ZL1 Camaro. GM has apparently fixed the isolator problems in these from previous versions.
** All parts come with their GM warranty **
Below are prices/parts of some of the rest of the stuff you may need/want:
Magnuson Heat exchanger from the Heartbeat kit for our cars - Roughly $475ish
Some guys ran the 2012+ GT500 heat exchanger for just a couple hundred dollars.
There will be hoses/clamps needed for the IC system. wiring/connectors/solder to extend MAF and the relocate the IAT wires from the stock MAF harness over to the IAT sensor on the lid.
Some people are using a Cobalt Filler neck PN 25884797 and cap PN 15076936 to fill the IC system. I do not have the PN for the cobalt tank as I planned on designing my own trunk mounted ice box and running dual IC pumps.
The 3 bar map sensor and IAT sensor come with the lid.
You use your stock MAP sensor from your stock intake to plug the hole for the snout pressure on the blower as it will not be used in our cars (only used as a plug, no connectors are plugged into the sensor).
There will be some fab work needed to run the ZL1 heat exchanger and maybe some others. Brackets will need to be made, misc bolts needed for the brackets.
Relocating the factory heater hoses is a must. Hoses with pre-bent 90's can be purchased from napa or any gates supplier.
A crank pinning kit is required to pin the balancer (~$75). Most just drill the new holes for the kit and do not use the key way on the LSA balancer.
The coil pack brackets need to be relocated slightly. Most just drilled new holes in the brackets to move them down towards the spark plugs about 1/2".
The fuel injectors and rail as they can be found used on the ctsvforums for VERY cheap. Stock LSA injectors are 52lb if my memory serves me correctly and CTS-V/ZL1 guys are selling them for under $200 some even as low as $100 for a set. Depending on your desired power levels 60lb or even ID750's or ID1000's may be needed.
A boost-a-pump isn't required if you stay on low boost but it will help if you start to turn the boost up so the fuel pump can keep up and not lose pressure. Or you can opt out to swap in an Aeromotive 340lph pump or even a Walbro 400 or 450lph pump with slight modification to the bucket.
I researched the fuel pump module in our cars vs the ZL1 and the part numbers are exactly the same, which means they are the same pump. So there is no need to "upgrade" to a ZL1 pump, because its already in our car. ZL1 pump should be good up to 600-650ish HP with a boost-a-pump. If you add methanol injection you can take a slight load off the fuel system and have room to grow for more horsepower as it will cool IAT's and increase octane.
I may have left some things off. As I start to dive into this conversion, which may not happen for a couple of months I will update the thread. Or as others on here begin the conversion and they leave feedback I will update this post.
This is just to get everyone started and ust about 95% of everything needed for the swap. Not all swaps will be the same as some may change a thing or two here and there.
This entire swap can be done for under $4k on the including LS9 cam ($115 or cheaper if found online used) if you do all the work yourself.
As part of the kit we are thinking of offering we are considering having a spare tire well mounted Ice box for the supercharger coolant to keep IAT's VERY cool or even COLD. The tank will consist of tubing wrapped in a coil that the SC coolant will pass through. Inside the tank you will be able to fill with ice and water to chill the coolant to close to 40-45* or colder which will bring IAT's well below ambient temps. We are considering opting out of running a heat exchanger as it would not be needed for further cooling.
#2 · (Edited by Moderator)
If only I had the know-how to do this type of thing on my own, I would be all over this. As it stands, I would have to have the work done, which significantly increases the price.
Shawn
Reactions: B_i_g_m_n_z
#4 · (Edited by Moderator)
Where abouts in Texas are you? I could help you get it done if you aren't too far. It wont require too much extensive work. Hardest thing may be pinning the crank for you or cutting into some plastic to make the heat exchanger work and making brackets. Other than that, its just nuts and bolts with a little wiring.
#5 ·
Couple of questions.
Is even remotely possible to do this in stages? If not i may just order a few pieces and then wait and then order a few more lol.
Is there a tutorial on completing the installation? I am fairly decent with a wrench and have some knowledge of the components, so i am just curious...
#6 ·
Im actually in Katy, Tx, near houston.
If i was going to do this, it would probably be around tax time next year. Got birthdays and xmas between now and then that take all of my extra cash.
Shawn
#9 ·
Shawn
Dam, thats kind of far for me. (kerrville, tx)
#8 · (Edited by Moderator)
No, I do not believe so. You can order the parts in stages, but as far as the install, you need to do it all at once. You can upgrade you cam before hand. The LS9 cam can be used with stock LS3 springs and only cost sub $115 from most parts houses. NA gains with the LS9 cam are 25-20hp from 4500-6500 but you will lose 20-25hp from idle to 3500-4000ish.
SS4ALL, I can live with that much rub... lol, no ****. Could even just cut out that section where it rubs but then it may look funny. Or simply remove the entire liner.
#10 ·
TXSS, I am down!
Reactions: topo444 and TXSS
#11 ·
What you really ought to talk to your boss about is setting up an E-Z-Payment-Plan... I can do $100 down and $25 per paycheck...
(and, yes, I'm joking...)
Thank you for taking the time to put this list together. If you do decide to market this kit (or even whenever the prices are finalized) please let us know -
I can certainly see buying the parts over time to put this kind of kit together - I'm patient enough to wait for the warranty to expire...
#13 · (Edited)
The dealer would probably more than likely void your powertrain warranty, but as far as the warranty on the parts itself, it would still stand with us. Im not sure exactly what the warranty on the blower and lid is, but I am looking in it.
But again, the dealer would have to prove that your modifications directly caused whatever you are in for.
Parts warranty is 12 month unlimited miles but there is a bulletin stating a 10yr/120k mile warranty on the LSA's in the ZL1 and V.
#14 ·
TXSS, what's your thinking on headers on this build? From what I read and per my builders recommendation they are good to keep back pressure and peak boost in check. The LSA SC puts about 10 psi peak boost with stock pulley. I have headers and ended up with 9 psi peak (8 psi avg over rev band) because headers dropped about 1 psi. The sound is also great...
#15 ·
You will gain boost as you increase the inlet airflow. But you will lose boost as you increase the exhaust flow. That doesnt mean you are losing power though. Through boosted applications the optimal setup would be 1 7/8" headers through a dual 3" setup all the way out to the tips. You CAN still use your stock exhaust, you just wont make as much power. 500rwhp will still be easily achievable with stock exhaust from manifolds to tips with this setup on an LS9 cam. With the LS9 cam you can retain your stock valvesprings even on boost. Its not really recommended but its not going to hurt anything or cause valve float. The cam doesnt have hardly any more lift than stock, the only changes are the duration which is the time the valves are open and the lobe separationg angle.
#16 · (Edited)
Since I recently did the ZL1 blower to my 2009.5 G8, figured I'd comment.
If those prices in the first post are real, they re pretty good. If offering a kit, post it up on the g8 boards and C5 -may be able to generate some volume.
I'd dump the GM dampener for a ATI unit. The GM dampener will wobble, resulting in belt chirp -almost all end up this way. And, the ATI has a keyway which makes the pinning process easy as well as future removal/replace for any work on the oil pump etc.
Injectors - I did the calculations, and new the 52lb lsa injectors would be close. I also have a tooley stg2 cam which pushed the inj duty cycle to 100%. Being conservative, I ended up with 60lbs injectors as it was just too close to lean.
If the fuel line comes up on the drivers side like the G8, you will need a Russell 641303 adapter (not a push on!), a 150deg and straight fitting along with some hose. I recommend PTFE -6 fuel line.
As it appears you have the ZL1 fuel pump, if you have the funds, I'd look at a vaporworks PWM controller with MAP reference, make the injector parms easy to set.
IC pump, I went with a ZL1/VOLT unit. Flows better than the generic bosch units (see the lingerfelter article) and comes with a bracket that mounts nice.
Ditch the TTL crank bolt, go with the ARP and heck, do ARP head bolts also.
If think of a mustang IC rad, look for the 2012 shelby or newer, it's 2" thick vs 1.5 for earlier. I got mine for 125 or so and it came with IC tank. It's a difficult install, ego wise, as now my G8 has Ford DNA in it. FWIW, I'm running the ZL1 IC rad and mustang in series.
I gathered my parts for well over a year, trolling the C5 ZL1, ctsvowners, ls1tech forums as well and watching Amazon warehouse (yes, they carry more GM than you realize)
And lastly, make sure your tuner is better than good and clearly has experience with tuning the LSA, in particular if you go with a custom cam- can't stress this enough.
#17 · (Edited)
The ATI dampener is an option. especially when we want to go with more boost. As of right now. Not a lot of people are going to jump up in boost right away so Im trying to offer this with as much stock stuff from GM as possible. I havent read of anyone having any wobble issues as I frequent the C5 and CTS-v and G8 forums. Maybe I missed it.
As far as injectors, and any other aftermarket items, I wish to not offer anything aftermarket in this kit as we could have to buy out and do PO's and CC charges, just makes for a paperwork fiasco here at the dealership for the accounting people.
Ive ran high boosted applications and never needed a MAP reference controller for my fuel pump. Ive ran boost a pumps with great success, or just upgraded to a larger fuel pump.
The faster the IC pump is pumping, the longer it takes for the fluid to cool. You dont want the fluid moving at snail speed, but it needs to be moving at a decent pace through the heat exchanger to get optimal cooling from efans pulling air through them. I am choosing to run twin bosch pumps as I will be building a trunk mounted ice box and will need the extra pump to move the volume.
Ive also ran the stock balancer bolts in in 700-800+ hp applications and never had an issue. If they are tq'd properly, they arent going to walk out on you.
I tune cars and have tuned CTS-V's and ZL1's so thats not a problem for me. As for others, yes, they need to do their research on who they are going to let tune their car.
Updated first post as I forgot the list the LSA intake gaskets.
#18 ·
TXSS, my post was not intended as negative to you, in fact I commend you on the effort to help out the forum with part numbers and pricing. Sorry if it came off that way. My intent was to share my experience only, give options from first hand experience.
Since I don't have a SS not sure SS folks will have the same challenges, ie the vaporworx for the FP was two fold , PWM power and the MAP reference. With a good tune, the map ref is not needed, but may make it easier as you will always have 58psi across the injector tip (in theory).
GM has a tsb for the dampener wobble, comes to belt chirp primarly. I have not read of many outright fails. I'm confident GM is fine, I preferred a true running pulley.
Regardless, nice job on all the work you have put into this.
#20 ·
I didnt take it in any negative way. In fact I know that I come off as a negative person with how I word things, its just how they come out, lol. Sorry for sounding like a dick, if I may.
We dont sell a lot of V's or ZL1's around here so we havent seen anyone come in with the wobble. Not saying they aren't out there, we just havent seen it yet.
#19 ·
WHAT ABOUT BELT DRIVE? I looked at this on my SS Camaro and the belt drive was wrong to do an LSA swap. The extra mounting bracket holes weren't in the water pump either. I don't have my car right here in front of me so are the Sedan's different?
#22 ·
I can offer this as a kit at the price posted in the first post. The kit consists of only the parts listed with the GM part numbers. If you want to add anything like the ZL1 Intercooler pump, please let me know and I will get you pricing. If you wish to opt out of the ZL1 heat exchanger, let me know as well and I can adjust the price for you. If you want a new fuel rail and new LS9 injectors, I can add those to the price tag as well. Shipping charges will occur on top of the listed price.
PLEASE NOTE: THIS IS NOT A COMPLETE KIT!!!
Most of the parts are coming out of Michigan and some are direct-ship from the source. It would take roughly 5-10 business days to receive everything before I could package everything together and ship it out.
#24 ·
CTSV and ZL1 owners like to mod too. Can save some coin by being patient and placing WTB postings.
I found yards don't like to piecemeal so much any more, they want to sell the whole assm. since they are late model parts.
#25 ·
The purpose of offering these parts new is so the buyers can have a warranty on their part. If they buy a used part and something happens to it, they chit out of luck and will have to come out of pocket to fix the issue.
#28 ·
PM me, the parts list is set but a few things you'll have to outsource.
#30 · (Edited)
Here's the list off an excel I updated a while back. Prices are without shipping, although many parts can be had for less (like injectors and shipping on those is negligible). Most places list the blower in the 1500-1700 region but shipping is about 300-400. I haven't gone to a GM parts desk yet to price the parts out. Pretty soon I'll have to start running to one :D
I haven't bought anything yet but I do plan on starting to piece the parts together so hopefully some beautiful spring day I can slap it on the car and start off with a base LSA tune and work from there. The other things that really should be added to the list is a wideband. Not a very good idea to run a diy setup (although factory parts) without one. Even if it is tuned by a pro. All it needs is one good long lean pull and the tops of the pistons are stuck in the cats.
I haven't updated the list for a while. Just wanted to chip in.
I haven't cross referenced the list below with the one in this thread so I might be missing something. The text is shamelessly copy pasted off simular posts for the G8.
Cost -> Part #
$1,555 -> 19257754 Supercharger with bypass
$298 -> 12622236 ZL1 Supercharger lid / 12631035 CTSV Lid
$14 -> 12612467 Lid Gasket/Insulator
$235 -> 12605222 Fuel Rail
$390 -> 12598646 LSA Injectors x 8
$38 -> 12639188 EVAP solenoid
$6 -> 11588718 SC bolts x 10
$112 -> 12603916 Crank Pulley
$8 -> 11570046 Crank Pulley Bolt
$54 -> 12606501 idler bracket
$81 -> 12606031 idler pulley
$63 -> 12606032 idler pulley
$27 -> 12606500 S/C tensioner bracket
$134 -> 12622452 S/C tensioner
$7 -> 11588749 Tensioner Bracket Bolts (x2)
$3 -> 11588742 Tensioner Bracket Bolt
$30 -> 12592525 3 Bar Map Sensor
$15 -> 12614717 IAT Sensor
$23 -> 25884797 226697069 Intercooler Filler Neck (This is a intercooler loop filler neck off a cobalt, you could do a tank or whatever)
$28 -> 22697069 Intercooler Filler neck Cap
39202200 2 Bosch Intercooler pump (This is the bosch part number)
$210 -> 20945282 GM Intercooler Pump (If you don't want to get the above off ebay for half the price..lol)
$6 -> 11588718 Intake Bolts (if you don't get them with your sc, you need ten)
$147 -> 22879421 Intercooler
$3,485
$118 12638427 Cam
$18 12586481 Cam Gear
$7 12556127 Cam Gear Bolts (x3)
$142.19
#33 ·
This is a waste of time. Go to camaro5 and look at all the LS3s and L99s that have had superchargers put on them. I know deep in your heart you want to believe that a supercharger will break your car as soon as you put it on. I know otherwise. When I was into the Camaro scene in Texas there would be tons of DD LS3 motors with superchargers on them. All worked just fine. Most of the failures I saw ended up being the TT cars with crazy boost numbers. This will be an easy swap with no long term durability issues that are not within the acceptable range for an LS3. just get a good tuner and dont use crappy fuel.
