Man, I get all the good luck on my car. First was my "discovery" of the inop GPS (CAN BUS wire bypass), then my rear defrost grid damaged (replaced rear window) and now a gooey windshield and flaky Lane Departure.
I am a perfectionist, in that even if I don't USE it, every feature in my cars NEEDS to work as intended (sans the 3G of course, can't control that one!). So I find myself in a new spot with my goofy '14.
The lane departure light is on the steering wheel but the beeping and graphic on the gauge cluster comes and goes. Did it three times this morning. Someone on FB suggested a dirty windshield, which I checked at lunch and now realize I have gooey oil running down inside my windshield, you guessed it, right near the lane departure/wiper sensor modules. I will dig in and figure out what the heck is going on. Crazy. Has anyone here changed these themselves? I have access to a GM scan tool and can program but it appears it may not be necessary, assuming I can get a used lane departure camera. They are a standard part across GM and NOT Holden specific (part number is 23356728).
I've seen two posts on this topic but no real answer as to what causes this. Looking for any insight as to what the oil "is" rather than just "cleaning it up and moving on".
FWIW, I have been working hard on a standalone solution for the 14 to run NPP/BiValve mufflers. Due to the bad weather across the country, all of my connectors and the ONE transistor I don't have in my box are stuck in shipping. I think I have a cheap solution with GM style connectors! More on that soon.
Cassidy
Cassidy
