Status
Not open for further replies.
1 - 10 of 10 Posts
Is anyone interested in a Kong 112mm throttle body? It is an early production Kong TB (made by Nick Williams) that is known to not handle high levels of boost and can go into limp mode. My application is north of 20 psi. The TB was used for engine break-in and caused no issues but was never put through its paces at higher boost levels. To rule out a potential issue I purchased another TB at full price. Ugh!!!
In speaking with Kong the TB should not be an issue for lower boost and naturally aspirated applications. New they are $1,049 plus shipping. $550 shipped to the lower 48. PayPal add 3%. My loss your again. Shipped in original box and packing.
Located near Albany, NY
Reactions: a6d9cmro
You have 30 minutes to bring this listing into compliance with the photos of the item for sale,,, or it goes to the "Twilight Zone"!!
ES
ES
That was quick. I qualified I was having an issue with photos. How does it look now?
Is anyone interested in a Kong 112mm throttle body? It is an early product Kong TB (made by Nick Williams) that is known to not handle high levels of boost and can go into limp mode. My application is north of 20 psi. The TB was used for engine break-in and caused no issues but was never put through its paces at higher boost levels. To rule out a potential issue I purchased another TB at full price. Ugh!!!
Wow! North of 20 lbs? What hp numbers are you putting down?
Is there a boost number kong recommends not to exceed? What is the outside dimension if the TB?
I'm interested want to understand the limitations.
Discussion Starter · #8 ·
  • Wow
Reactions: wilkin4
Discussion Starter · #9 ·
He didn’t have a boost number but indicated should be ok under 800 hp.
Not sure what dimension you are looking for. A 4.5” coupler will work with the TB which is 4.75” OD. The coupler will stretch.
Discussion Starter · #10 ·
Sold
Reactions: 15SuperSport
1 - 10 of 10 Posts
Status
