For those who have done the airbag swap, did you pull your airbag fuse, or go with just disconnecting the negative battery terminal only?
Thanks.
Thanks.
I installed mine last week and only disconnected the negitive battery cable. No problem during the five minute install or after reconnecting the battery.For those who have done the airbag swap, did you pull your airbag fuse, or go with just disconnecting the negative battery terminal only?
Thanks.
It explains this in the very first post of this thread.Great info, but before I actually try to remove the airbag, can someone further explain how to disconnect its connectors? I'm doing the blackout trim swap.
I read the first post, but this not clear how the electrical connections for the airbag are undone. Do they just pull out? Are we talking about the orange connectors in the picture on the airbag side?
I don’t believe so, if I’m wrong someone will correct me.somebody know if I can Install head airbags from G8 in a 2015 SS ?
thanks
thanks
I would err on the side of caution. Unless the part numbers are the same, they probably differ. Just the safety advances of 5 years could have seen changes to size, shape, velocity, etc. I'd personally not take the chance unless there was evidence available supporting the interchangeability.I don’t believe so, if I’m wrong someone will correct me.
