1 - 2 of 2 Posts
hi, i have SSV 2017, i did hsv gts s2 conversion but i got only one problem with the taillights, that middle right and left taillights it’s on breaking light all time, (with / without breaking ), but the ( Outer) right and left works fine.
Isn’t because of the old taillights were normal not led so i need crank voltage or should i do something with wiring?
Do the HSV lights have pig tails on them? They may have the terminals pinned incorrectly (I've had it happen) and the park light pin is switched with the brake light pin, which will give you this exact scenario. Also, with the headlights off, try pressing the brake and see if it's dimmer than what you show currently.
1 - 2 of 2 Posts
