1 - 8 of 8 Posts
I am in need of better fuel injectors, since the LS9 injectors that came with my Magnuson SC are at 97% duty cycle with the 81mm pulley I am now using (which I know is not a good place to be :/)
During my research it seems that the ID1050X are the gold standard at approximately $900-$1000 for 8?
The runner up seems to be the Bosch 110lb EV14 at $529 from TRE Performance?
I am leaning towards the Bosch set since the price is about 1/2 the cost of the Injector Dynamics kit. But I don't want to shoot myself in the foot considering how much money I already have invested into the build, that I could compromise by going with inferior injectors.
Suggestions and recommendations are welcomed. Negative or positive.
When I had the kit installed, I had them swap ID850s for the LS9's and I paid the difference in price. The ID850s have now been replaced by the ID1050x's which didn't exist 2 years ago. The ID850's can supply more fuel than I could use, even if I went to corn and of course I'd need a new fuel pump to do that. I don't have plans for that, just wanted extra headroom in case I go crazy and want big big power. If i did it today, I'd use id1050x's. Keep in mind that an injector swap, like the pulley swap and tune invalidate the CARB EO.
I'll be selling some id850s with 1500 miles on them if interested. 550$
Reactions: austinb and TXSS
Siemens 107962, which are the GM ones. OEM quality and reliability and the injector data is readily available, which is key.
Banned
FIC (Fuel Injector Connection) if you need injectors let me know.
Reactions: supercharged
Wow, I hadn't seen you on here in so long I figured the mods were flexing their powers and banned you. :)
1 - 8 of 8 Posts
