1 - 10 of 10 Posts
Driving at night I noticed that left head lamp shining more to left lighting up left side of 2 lane road IE fields. The right side seemed like it was less to the side of the street. I feel the headlight aim is reversed for USA driving thoughts please. I think they are aligned for AU since they drive on the other side of the road.
Doug:eek:hmy:
Doug:eek:hmy:
Maybe it's related to the Lane departure warning system. ???
· Banned
Doug:eek:hmy:
At least in my state it would fail state inspection being that way!
I would tweak it myself!
Doug:eek:hmy:
Stop 10' from your garage wall, if the headlights rise to the left like mine someone will get a butt kicking, yours should rise to the right side.
Discussion Starter · #8 ·
Stop 10" from your garage wall, if the headlights rise to the left like mine someone will get a butt kicking, yours should rise to the right side.
That is 10 inches not 10 feet want to be sure I get this right.
I just think it would be easy to mix up building both on the same assy line one right hand and then left hand.
Thank you
yep, 10 inches should do the trick, I haven't adjusted headlights in years, There should be two screws on top of each headlight assembly. One does horizontal axis and the other does the vertical axis. I haven't seen the screws but they may be white..
In the SS owners manual it says to see your dealer if adjustment is needed. Should be covered under warrantable items I would imagine.
Discussion Starter · #10 ·
Thanks commodoreman will do this this evening it's turkey day here will be at daughters house most of day this is something I need to do after dark.
1 - 10 of 10 Posts
