All American Sunday, first autocross event for the SS. Had a ball. Tip would be trust the brakes, they are very good. Trick is convincing people that it isn't a Malibu before you go out...
Thanks man. Make sure your front tires are aired up well, found about 40-42 psi to be good, less seemed to roll the sidewall. Also, don't hit the mute button on the dashcam before the event... :bangheadonwall:Seems to be a tight course which you handled well...
Any other advice for potential AutoXers?
We ran our '12 Caprice 9C1 at our last regional autocross event. Started with 45#F 42#R and let the pressure drift up with the heat in the tires. I added a bit in the front as the day went on. Ended up with 53#F, 49#R and I think a bit more would have helped. Street tires and the lack of camber, more pressure can help keep what little tread that's on the ground planted.Thanks man. Make sure your front tires are aired up well, found about 40-42 psi to be good, less seemed to roll the sidewall. Also, don't hit the mute button on the dashcam before the event... :bangheadonwall:
http://www.youtube.com/watch?v=LdqQaNwxHJU
That is because it is high. I bet it is 4-5psi higher than what the maximum tire pressure is for that tire. I ran 45/37psi in the stock tires and barely touched the shoulders. I also run the same amount in my Z2s on a '13 Boss 302 without issue.That just seems so high, but I guess you know your car.
For reference, last year I was at 33F/R in my CS M3 on Z2s. I had less than a degree of negative camber per side.
My brother runs 34F/32R in his FS '12 Mustang Brembo Package on RE-71Rs. He also has little negative camber.
