For those who might care, the EPA fuel economy numbers are up for the SS:
Compare Side-by-Side
14/21, not too bad for what it is...
oh well it wont matter all that much to people who buy this car since they are buying it knowing its a powerful $45k+ V8 performance sedan!The new Ford and Chevy V-8 pickups are rated better. This engine is inefficient. The trucks have way more drag.
Yea i was just looking at that, SS and the SRT are identical in the city, its only on the highway the SRT has a 2 mpg gain on the SS which yes would be easily explained by the SS' taller rear gears.The Charger SRT8 has 55 more HP and is 400 lbs heavier and its EPA mpg is about the same as the SS. Must be that higher rear end gear ratio of the SS at 3.27 vs. the chargers 3.06. ???
At least we can expect the next generation SS to be much more fuel efficient, they'll probably end up dropping the V8 for a twin turbo V6 which will help a lot.Yea i was just looking at that, SS and the SRT are identical in the city, its only on the highway the SRT has a 2 mpg gain on the SS which yes would be easily explained by the SS' taller rear gears.
Also interesting the SRT Charger comes with auto 5 while the SS has an auto 6....
Carbon Fiber is interesting, with so much steel in demand from developing nations i think makers are going to have to start turning to other materials. But CF is still very expensive, $10 a pound for low-grade still. 5$/pound would be the magic number to start seeing companies like GM get heavily involved with CF. The problem is right now the base material in CF (polyacrylonitrile) already blows the nut on that 5$ price ceiling.At least we can expect the next generation SS to be much more fuel efficient, they'll probably end up dropping the V8 for a twin turbo V6 which will help a lot.
Maybe by then we'll see some carbon fiber parts added, the use of carbon fiber in vehicles on a manufacture level is becoming more mainstream now.
Yeah, I'm holding out some hope that they'll pull a "GTO" and put the newer engine in for the second model year. It would seem to make sense from a production standpoint since most of the other cars/trucks will be switching to Gen V engines by then too.Just wait for LT1 460 HP will make over 25 mpg easy on this car! Also with 7 speed manual!
