81 - 90 of 90 Posts
How bad is the smell, is it as bad as you ran over a skunk bad? Or burn your eyes bad? I don’t plan to sit idling too long at lights or in my garage.
How about exhaust rasp? Any issues?
The smell is not bad, not bad like a skunk, just is a smell. Guess I'm use to the smell. I have yet to actually drive the car with the DT installed now. No report on rasp as I'm waiting on some wheels to arrive.
Keep us posted on the drive sounds and smell
Any updates to share? I'm considering these for my 2015, but will likely keep the secondary cats and stock mufflers.
I ordered them about 3 weeks ago but they are on back order or something with end of April possible ship date.
Finally just yesterday took the SS for a spin after installing new polished V wheels and new rubber. The sound output from the DT headers without any cats or 2ndary cats isn't loud at all even in sport mode with bimode exhaust. It's not raspy at all, is a little deeper tone but to me still very mild. Tour mode is practically the same as stock. Only time I could smell anything was in the shop as the car warmed up.
Time for me to order! I think these headers are a great add for people like me who are city drivers and don’t plan to run the car on the track or strip. All I want is a little bit more hp/torque to go up against the Mustangs, Scat 392, etc.
Reactions: generalg
did you throw any codes after the install? I keep reading some ppl end up throwing codes due to no cats etc and needing the rear sensors coded out. thanks again
I still haven't drove the car more than 30 miles since installing the headers.... No codes as of yet. 😁
well I didn't read the instructions well enough and didn't remove the passenger side heat shield covering the starter. The headers were touching the heat shield in two main spots, and a cable. I zip tied the cable back so it wasn't touching the header, and was able to bend back the heat shield slightly in one spot as to not directly touch, but its still touching in a higher up spot I cannot reach with any tool. I'll have to see if I can remove the starter first (and then its heat shield) so I don't have to do the passenger side header all over again..it was a big pain.
81 - 90 of 90 Posts
