1 - 4 of 4 Posts
wanting to upgrade speakers and do a little noise abatement. started at the rear left and things were going smoothly until I tried to remove the panel.
I believe I have the 4 required screws out and all of the pins and clips are free. I can see that the door handle cable is still attached, but that is not my problem.
I proceed to lift and turn the panel, I get up and inch or so, and twist outward maybe two inches. I do feel a release coming from near the center of the panel, then it stops. I'm applying probably 10-12 pounds of force.
Are there clips near the center of the door panel?
How much force is necessary to release the panel?
Have I missed a screw? The diagrams are very straight forward.
Thanks
Hoopla
home to "Sleeping Beauty"
Search, on this site, is your friend!! Look up "Front Door Panel Removal". It is from 2/8/16. Good diagram and instructions!!
thanks for the inputs, I finally realized that I removed the wrong screw in the door arm rest area, then things came apart nicely.
Thanks
Hoopla
1 - 4 of 4 Posts
