So, in my daily/weekly routine, I get to drive fairly new vehicles on a regular basis--from a dealer to a detail shop, in come cases over 20 miles each way, on Interstate-grade roadways (up to 70 MPH, which I push to 79).
One thing that happens occasionally is that a "speed limit exceeded" warning--both audible and on the DIC--comes up...I have yet to drive an SS on this route, but I do drive quite a few Silverado pickups with this feature. I "assumed" it was part of Navigation/GPS that keeps track of vehicle position and has programmed data that alerts the driver if the posted limit pinpointed by GPS is exceeded by some threshold amount.
Maybe that's not the case....I just happened to go faster than the warning setting....imagine that!!!
From Owner's Manuals:
2015 SS Sedan
Instruments and Controls 5-22
Speed Warning
This display is used to set the
vehicle speed at which the speed
warning chime sounds and the alert
is displayed. The speed can be set
by pressing SET/CLR while the
speed warning display is showing.
2015 Silverado
Instruments and Controls 5-13
Speed Warning: The Speed
Warning display allows the driver to
set a speed that they do not want to
exceed. To set the Speed Warning,
press p when Speed Warning is
displayed, or press V on the main
view to set the speed value. Press
w or x to adjust the value. Press
V to set the speed. Once the speed
is set, this feature can be turned off
by pressing V while viewing this
page. If the selected speed limit is
exceeded, a pop-up warning is
displayed with a chime.
