Decided to write a thread semi-documenting my Whipple Install. Took me a few weekends, several late nights and a bunch of trips to ACE/Home Depot, but the end product was more that I could hoped for. For starters, I got this kit used off a friend who had sold his SS for only $5k with all new hoses and lines from Whipple. But it is a used kit that sat for a while so there was the hassle of ordering a Whipple tune and random parts/bolts and nuts I couldn't find.
We'll start with the inventory of parts
Then began the process of taking everything apart (While my actual project Trans Am sits on jack stands in the back)
Then came time to modify the Roto-Fab. I knew it was possible however every thread literally only stated to "trim the bottom of it" with no pictures or reference as to how much I had to cut to fit it, so here is how much I cut/modified the Roto Fab (I ended up being too lazy to buy a dremel cutting wheel for plastic and just melted it with my gun stippling kit)
With everything good to go, I took it out for a quick easy spin, came back and called it a night:
next day, I started it up and there was a Oil Pressure code.. of course the OPS would fail the day after the S/C install.. ordered a new one, ordered a special open end wrench that hooks up to a ratchet to do the install since the S/C is now in the way of a regular oil pressure switch socket, replaced it and cleared the code. Drove around and never threw another code.
That night a friend comes over to check out the car, I warm it up, give a nice rev to 4k rpm.. start hearing belt chirp and smelling burnt rubber... uh oh...
order a Pulley Puller, Installer, ATI balancer, replacement Belts and the cars down for another week
hardest part was since the stock crank and balancer was pinned in the install, I had to drill the ATI's hub and with dowels, then slowly line it up with the holes I drilled in the crank as I pressed it on. Luckily I was able to reinstall it and get everything running again.
Took it on the freeway for the first time and gave it the beans, good god what is that rattling noise?!
It's way too loud to be pinging/detonation right? It has to be exhaust hitting the crossmember or exhaust heatshield rattling... nope.. time to call a tuner..
Canned Whipple tune was so bad (Timing too advanced and running too lean) the Tuner (Newtech Performance in Hayward CA) couldn't even get a safe baseline run with the canned Whipple tune.
He worked his magic and after a couple hours got a safe reliable tune uploaded into the car. The car put down 550 RWHP and 492 RWTRQ (STD correction) with a conservative safe tune and I was stoke! He's done quite a few SS builds/Tunes in the CA Bay Area and says on the same dyno he usually sees 360-365 RWHP (highest was 370 on a manual) on the stock cars with the same Dyno settings.
Not only did the detonation disappear, the drivability improved immensely. With the Whipple Tune there seemed to be a wall where 28% throttle there was no boost, then 29% throttle it would slam into boost the power delivery was inconsistent and harsh.. The car ran rough and even stalled a couple times on me. plus the throttle response was HORRENDOUS. With the custom tune the car drives like it did off the showroom floor, with just way more power. It's smooth and linear in it's power delivery and completely predictable.
And FINALLY, to celebrate the end of this saga, I went and did a quick photoshoot
only complaint... I wish there was more supercharger whine... I can barely hear any... and only around 2-3k rpm when slowly accelerating from a stop...
