Awesome thanks for the input.It is built in. They give you different fittings than the stock radiator...but it all goes together
Bump for help - Where’s all my hands on guys?Ok, for those that have installed the cold case (or other new radiator) in the SS, how hard is this, any special tools, etc? I assume I need to pull the front clip bit I can’t find anything online specific to the SS as a reference.
I have no problem doing this myself but want to have an idea what I am getting into. Thanks in advance.
Well I think I found the problem. I bent the A/C line against my better judgment and proceeded with the mockup. What I found is the VCM intake doesn't line up with the throttlebody now. So I measured the overall height (from bottom puck mounting location to top of radiator) and found the Cold Case to be a full 1" taller (about 18.5" compared to 17.5"). Argh so pissed off right now.Hmm, I'll have to check mine, but I don't recall those lines interfering. I do recall being aware of the tight fit near the cap with the existing hard line, but I thought I cleared my lower lines well. I'll take a look and let you know what I find.
I called Cold Case tech support. They said to measure theirs and the factory radiator and compare to the specs posted on their website. Here is what I came up with:Please keep us posted. I have the VCM also. I've had the LMC100A in my shortcuts since it first showed up.
