In this thread, I posted:
On the SS, the radius arm is the cast or forged aluminum part that can be viewed under the car, running forward from the bottom of the front suspension strut to it's frame mount - on both sides, one per side. It's task is to maintain the strut at it's optimum angle of inclination (ie. caster) and at the same time absorb impacts - there is a bushing in the forward end of the arm where the arm is attached to the chassis for this purpose.
In this photo, it's the silver-colored part behind the rotor running off to the left (to front of car):
High caster (much more than is found on older suspension designs) is generally considered preferable, as it aids in directional stability--ie. "more is better", within design limits--considering the high level of chassis dynamics in the basic Zeta chassis, and the high-performance driving conditions this vehicle was intended to excel in.
Further investigation has revealed some options that actually do provide a small degree of adjustability to both camber (beyond OE provisions) and caster. The following links are from several sources/brands, and if you dig far enough once inside the links, you'll find installation instructions with illustrations (PDF's, mostly) that will provide better clarification of what is being done in each case than I can adequately describe here.
CAMBER adjustment - in addition to available OE adjustment
(several suppliers offer similar offset strut-to-knuckle bolts)
SPC EZ-Cam 81280
CASTER adjustment - several suppliers offer kits
BMR Suspension - SPF-2959K caster plates
supplied by SuperPro - Australia
Pedders Suspension - radius rod bushings & caster lock washers
consists of: G8 EP6560 Radius Rod Bushings, includes 5421 kit
G8 5421 caster lock washer kit - available separately (also fits VF chassis)
per Pedders, this kit adds +1.25 degrees of caster
Whiteline - caster correction kit W83172
radius arm caster correction lock washers W53152
US source - example
per Whiteline, this kit adds +1/2 degree of caster
Whiteline actually lists Chevrolet SS as supported model - list of products that are available
My statement above was in error (which can no longer be edited), so I wanted to clarify--the caster "adjustment plates" mentioned above are NOT for the top of the struts. These plates are used on the lower radius arm(s) to "pull" the lower end of the strut(s) as far forward as possible--up to 1.25 degrees of added inclination (ie. caster) according to one supplier--thereby increasing the 6 degrees+/- "target", to set caster at or near the maximum recommended limit.Caster is pretty much fixed in the design of the Zeta suspension. It would require adjustment plates at the top of the struts to change caster--race level stuff. Note this listing (by CP) in another forum - caster plates and other suspension parts
There is an acceptable range to allow for production variation and to tell if there is something "wrong" with the car if caster is outside acceptable range. Camber and toe are adjustable.
SPC EZ-Cam 81280
US source - example
