1 - 8 of 8 Posts
Hubcentric spacers work well... I've been running them on my Camry on them for 3 years now, taken the car on mountain runs and all, and have never had a problem. Car rides smooth as well. Just make sure the hub bore on the wheel matches the hub bore on the spacer and that the wheel studs are long enough, at least a quarter inch protruding after the wheel is placed, half inch is optimal IMO.
As for measurements to use for the hubcentric spacer, I would need to know the offset of the aftermarket wheels in comparison to the originals to be able to help you out. In essence (not in every occasion) spacers correct offset, which in this case, brake clearance=offset issues...
I am by no means a wheel expert. I am solely speaking based on experience and opinion.
Why would you want to take off your 245 or 275 and put on a 235 on your SS. Smaller tire than a Cruze LTZ.
The reasoning behind it is solely for winter tires. Narrower winter tires get better traction by concentrating weight on a smaller surface area. This provides better traction relative to the same weight on a larger a surface area. It allows the tire to 'dig into' the snow better and lets it plow through the snow instead of riding on top of it.
You would want wheel spacers like this
A 15-20mm spacer should do you good. Problem with spacers that don't have built in studs is that you will be reducing the amount of threads the lugs are holding the rims onto the hub by using the spacers you have posted. Which could be dangerous.
You could even keep it after in the rear to give you a wider stance :)
Discussion Starter · #7 ·
I am concerned about using such a setup, I only need approximately 4 mm space, 15-20 mm seems overkill. I agree on the lug length, that is an issue.
Just FYI; From working in a machine shop I learned that thread strength is no greater than it's diameter. I.E. if it is 1/2" diameter bolt (1/2-13, 1/2-20, etc.), any more than 1/2" worth of thread length will not increase the strength. Or you wouldn't need any more than 1/2" grip length.
1 - 8 of 8 Posts
