1 - 20 of 62 Posts
Any recommendations for 48AGM battery replacements? I see the AC Delco OEM replacement but looking what others have used.
I have a 2015 with 18k miles and can tell its starting to show its age. Slower cranking and some electrical gremlins- tell tell sign.
Got my oem on summit racing think it was a tad cheaper on there, i noticed my dash cam was going off at low voltage quite often in parking mode.
I'm getting to that point too. I'm going to go OEM and was wondering about buying on Amazon. i.e. Amazon doesn't do the best job of packaging, so I'm wondering if the battery will survive shipping undamaged.
Even though I thoroughly dislike AC Delco batteries, they are our only choice.
I purchased my last my last one from Summit and it was packaged better than my previous one from Amazon.
all the big brand parts stores sell/can order Delco. O'reilley, Autozone etc.
I would stay with Delco because of the valve regulated.
That's my normal route. But I'm thinking that letting Amazon or Summit deliver to my home will save a trip.
How are they packaged?
t
The ones I received were in a heavier cardboard box with fairly thick white foam surrounding the battery on all sides. I would consider it very well packaged. If price is close, I may opt for a local dealer so long as date code is good. The two delcos I got for my Impalas were $40 less on amazon at the time so that’s the routs I went. The other was a Bosch for a Honda and it was about $30 cheaper on amazon than local shops.
Aren’t all sealed AGM batteries “valve regulated”? Is there anything special in the Delco brand battery that isn’t present in other brands or in a battery brand made by the same maker that makes for Delco? (Johnson controls?)
The new one has vent on both sides and a plug is provided for the one that is not used (vent tube on rear) fyi for those not knowing as i didn’t at first.
168.99 on summit currently, free shipping
Reactions: Sporrt Smith
nevermind
Why run the same middle of the road AC delco battery when there are better options available?
Odyssey Battery 48-720
Pulse (5 second) Hot Cranking Amps (PHCA) 1250
Cold Cranking Amps (CCA) 723
20Hr Nominal Capacity (Ah) 69
Reserve Capacity Minutes 130
Dimensions L x W x H (in) 10.91 x 6.89 x 7.5
Weight (lbs) 48.0
Weight (kg) 21.8
Warranty: 3 Year
279238
North Star NSB-AGM48 (L3)
Pulse cranking amps 1320 A
CCA rating at -18°C (0°F) 775 A
CA/MCA rating at 0°C (32°F) 910 A
Reserve capacity 135 min
Capacity - 20 hour rate (1.75 vpc) 67 Ah
Internal resistance 3.7 mΩ @ 25°C (77°F)
Short circuit current 2357 A
Warranty 4 years full
Height 7.42 in
Width 6.87 in
Length 10.91 in
Weight 49 lbs
279239
Or Batteries Plus SLI48AGMDP which is made by North Star
Lead Acid Type: Deep Cycle, Dual Purpose (Starting/Cycling), Starting
Capacity: 67AH
Cold Cranking Amps: 775
Battery Type: Ultimate
Capacity 20hr: 67AH
Chemistry: Lead Acid
Cranking Amps: 915
Lead Acid Design: AGM
Made in the USA: True
Maintenance Free: Yes
Warranty: 60 Month Free Replacement
Weight: 48.6 lbs
Length: 10.9 in
Width: 6.9 in
Height: 7.4 in
279237
Yeah these are more expense, but they last longer that most run of the mill AGM batteries. Usually two years or more longer! Speaking from personal experience having used both & still do. The batteries plus model does carry a better warranty. Also if buy from their website you get anywhere from a 10 to 20% coupon code poping up to use instantly.
Weight (lbs) 48.0
Weight (kg) 21.8
Warranty: 3 Year
Height 7.42 in
Width 6.87 in
Length 10.91 in
Weight 49 lbs
Capacity: 67AH
Capacity 20hr: 67AH
Cranking Amps: 915
Weight: 48.6 lbs
Length: 10.9 in
Width: 6.9 in
Height: 7.4 in
Thx , That’s exactly what I was wondering why I go back to that battery if you could go better would it make a difference in electronics system I mean 12 V will be 12 V with the longevity and endurance is what we’re looking for right so why not upgrade ???
It's NOT a good idea to use a "Dual Purpose" Battery in a motor vehicle. It simply can't provide the same performance as a "starting" battery.
Capacity: 67AH
Capacity 20hr: 67AH
Cranking Amps: 915
Weight: 48.6 lbs
Length: 10.9 in
Width: 6.9 in
Height: 7.4 in
Discussion Starter · #20 ·
Researched and shopped around. Decided to go with Duralast Platinum. Local and specifications look good.
$199
-18.00 core
-20.00 military10% discount
$161 total.
1 - 20 of 62 Posts
