Howdy...this isn't a how-to or anything...just charting the progress of my LSA install. I happened upon an LSA blower from a ZL-1 back in October of last year and I couldn't say no. Thanks to the guys here, Eviltwin and SyP come to mind first , I decided that this would b a very doable project. I began ordering parts from GM right away based off the list (TX_SS?) in the FI section and the G8 forums over the last few months...I installed things like the pulleys, LS9 cam, intercooler tank and crank pulley since they don't impact normal driving.
Today, the intercooler was installed...My guy is waiting for a few fittings before we drop the blower on...I'm really getting excited. I'll try and sort thru the pics on my phone and post them up...:grin
EDIT
Ok, so some things went wrong and I hurt the motor, so this is an updated list of what’s in the car now
Engine: 417CID with 9.8:1 compression, Manley Turbo Tuff rods, Manley forges pistons and Manley 4” forged crank.
Stock heads with Manley springs, locks , retainers.
Kong LSA 2650 blower & ZL1 lid (reinforced brick -12 fittings) with 3” upper, ATI 8.6” lower on ATI damper.
Nick Williams 102mm throttle body with home made intake, modified Rotofab box.
Cooling it down is a PnP Frostbite Chiller, no front mount IC. Glanzer 2+ gallon tank and ‘13 GT500 IC pump finish off the cooling system.
Transmission: rebuilt 6L80 with ZL1 converter and improved HD clutches. I also modified the valve body with a Sonnax “Zip kit”, which has better valves, springs and 8 check balls instead of 7 for the updated plate. There’s a billet intermediate shaft and improved pistons as well.
Driveline: one piece 3.5” driveshaft (installed), Detroit Locker TruTrac diff and G-Force 1500hp axles - which will be installed soon.
Rolling stock: Weld RT-S 17x4&9.5 drag setup with MT front runners and DRs (305s)
Run the factory wheels and tires for street duty.
So I’ll keep the original info so that some of you can see the evolution, but this gives you a glance at the current state of things [emoji41]
EDIT
