441 - 460 of 494 Posts
That looks good, a bigger tank will do wonders for you. I was told to stick to 2ish gallons if possible at the minimum for a chiller. That gets you a full 1/4 mile pass if the system isn’t actively chilling.
Reactions: Fedge378
Yes sir, its right at 2 gallons. I have to run the lines like this now: Blower, pump, tank, chiller, blower...hopefully, no issues to be had.
@Fedge378- sorry to thread jack!
Discussion Starter #443
Ha ha no worries - besides, I like seeing other builds and ideas tossed around, gives me options
@Fedge378 ; you update the “what have you done to your SS” thread more than this one
Discussion Starter #445
Lol true story - updates are coming!!
Hey man, he's keeping one of my lame threads relevant. If you scare him off I'll have to merge the threads ;)
Discussion Starter #447
Ok, so this weekend has been pretty productive. Air and correct tools have certainly been a benefit, as in my younger days, this would have been a shitshow lol.
Drivetrain is all done, trans cooler lines, for all you ambitious folks out there, should be installed at the trans before the wiring for the starter (and shield) are in place lol - oh and the compressor!
Heads are on, so I’m taking a break while I’m still enjoying the work and my foot isn’t trying to fall off.
Discussion Starter #448
Headers go in really easy
HOWEVER
effing Kooks to Corsa connection pipe doesn’t fit said system. It’s short. I’m displeased. Now I gotta figure something out. I guess I can have it towed to the muffler shop.
HOWEVER
effing Kooks to Corsa connection pipe doesn’t fit said system. It’s short. I’m displeased. Now I gotta figure I'msomething out. I guess I can have it towed to the muffler shop.
How hard was wrapping the headers? Thinking of wrapping mine to cut down on heat.
Discussion Starter #450
I gave it the old college try and then gave it to a shop after I ran out of talent
Reactions: jcoulter36
Discussion Starter #451
This is how off the exhaust is, by the way...
Discussion Starter #453
Flex seal is the only solution
Anywho, rockers on and torqued, valve covers on and torqued - got that dipstick tube in. So much fun, ugh.
I’ll call the exhaust shop and see if they can get me in by the weekend.
Reactions: wilkin4
Discussion Starter #454
Me thinks the 2” may be shorter than the 1-7/8”. I can’t see why the connection pipes wouldn’t fit otherwise
Discussion Starter #455
Testing fit with tank and larger inlet
It’s all installed now, torqued and what not. Waiting on injectors. Ordered a new belt. Done for the day. Tomorrow I will install plugs and I guess I’ll work on the cooling.
I should probably add all of the fluids too
Reactions: wilkin4 and good2go
Discussion Starter #457
Nice, can’t wait for the numbers
Thanks, me too!
Sooooo close. Dropped a damn hood nut and can’t find my magnet! Ugh.
Waiting on injectors and the blower belt.
Then off to the muffler shop to fix that issue, then the tuner
Discussion Starter #458
No more parts to install besides injectors
Drag gear
Street gear
Reactions: wilkin4
Discussion Starter #459
Took matters into my own hands...
Got my trusty Sawzall and a Sharpie...two stainless couplers and made all the adjustments. Now I just gotta get it all welded up, and that problem will be solved
And in other news, I got to pump in 8.5 quarts of trans fluid. Gotta run the car, get the trans up to temp...maybe shift it a few times from park to drive before it’ll take the rest.
Reactions: wilkin4
So much awesome here...😬
