1 - 20 of 33 Posts
  • Spare Tire - 245/40R19
  • Spare Wheel - 19" x 8.5" (48.3cm x 21.59cm), aluminum
  • Front Tires: 245/40R19
  • Front Wheels: 19" x 8.5" (48.3cm x 21.59cm), polished forged aluminum
  • Rear Tires: 275/35R19
  • Rear Wheels: 19" x 9" (48.3cm x 22.9cm), polished forged aluminum
  • Summer Tires
their is more than the pattern, (120 mm) you also have the offset, and centre hub diameter, most stores will have the info you need, this platform has been in the US since 2008.
it should be the same as VF Commodore which has a PCD = 5x120, centre bore=66.9 and offset=45
In saying that, looking at G8 it was slightly different according to this site PCD Pontiac G8 (2008 - 2009) 5x120 wheels | PCD, Offset, Center Bore, mounting and tire size data
Yes, I am getting some different numbers based on the sites I visit also.
However, I already have a set of wheels from a 2010 LaCrosse, and from what I can tell the bolt pattern is the same, the offset range is similar and the center bores are very close (the wheels might be 0.5 mm larger) so I might be good.
1 - 20 of 33 Posts
