IATs are crazy high. HELP! - Chevy SS Forum
 22Likes
Reply
LinkBack Thread Tools
post #1 of 41 (permalink) Old 04-24-2019, 09:11 PM Thread Starter
Senior Member
Hi everyone. I picked up my car today after having an LSA installed and my IATs seem EXTREMELY high. My readings are coming from my HPTuners nGauge. I only get one reading right now which I believe is IAT 1 and it creeped up to almost 160į while I was in traffic. Outside temp was about 72į.
What the heck is wrong?
My setup:
- Completely stock and un-altered LSA blower (replaced the coupler, thats it) with stock pulley.
- ZL1 lid
- custom hx from a forum member which fits behind the factory grill without any cutting or relocations. Slightly larger volume than a stock ZL1 hx
- varimax intercooler pump
I do not have a seperate "expansion" tank
MichaelSS15 is online now
Sponsored Links
Advertisement
post #2 of 41 (permalink) Old 04-24-2019, 09:46 PM
Senior Member
My setup:
- ZL1 lid
Open air cleaner sucking underhood hot air ain't doing the temps any favors.
2017 SIM ROOFLESS SPARE AUTO UNSULLIED
2,701st of 4,008 built 2-5-2017
12th of 17 built as configured
2014 SIM ROOFLESS - Traded
2,703rd customer car built
1 of 73 ROOFLESS SIM customer built cars
1 of 78 total ROOFLESS SIM in US when including the 5 roofless SIM GM internal cars sold as used.
1 of the 78 is confirmed dead and unrecoverable.
I don't do lazy or stupid.
Proudly politically incorrect.
CB750 is offline
post #3 of 41 (permalink) Old 04-24-2019, 09:50 PM
Senior Member
LSPowered65's Avatar
My setup:
- ZL1 lid
Best you will ever get is within in 10-20* of ambient temp while MOVING. Sitting still you have a solid chunk of aluminum sitting on top of another solid chunk of hot aluminum. Verify that your supercharger coolant pump is working properly and that all the air is out of the system. If neither of them fix you up you can always look into ditching the h/x and tapping into your a/c for 50* iat all day long. Chances are your pump wasnít working or you have air in the system still. Good Luck
2017 SS M6 LSA Kooks LT & Mids Crane Cam ID1050 2.55"
NewEra ZL1 CAI 675rwhp 602lb/ft 93 Octane
2018 Sierra Denali 6.2 A8
2016 Jeep Grand Cherokee 3.0 Diesel A8
1965 Impala 5.3 ls, M6
LSPowered65 is online now
post #4 of 41 (permalink) Old 04-24-2019, 09:55 PM
Senior Member
CB makes a great point and it would be helpful to know if you are running off the temp sensor in the lid or the maf.
post #5 of 41 (permalink) Old 04-24-2019, 10:38 PM Thread Starter
Senior Member
Quote:
Im not positive, but I think its the sensor in the lid.
post #6 of 41 (permalink) Old 04-25-2019, 12:06 AM
Member
RoushSenator's Avatar
Without going to a full forced induction interchiller, you can order their blower spacer plates, and coolant reservoir. These are common LSA choices in Australia, without the complexity of an interchiller. Definite chiller free drops in IAT, not too much complexity. I went the whole hog with an interchiller, but the LSA is a modern upward displacement blower unlike mine.
HSV Senator
Underway
Callies Compstar Rods
Carillo CP Pistons
Mellings Oil Pump
LS9 Engine Block
Cam change
Installed
Roush 2300TVS supercharger using WASP (Ford supercharger to LS engine) kit. WASP Laminova intercooler.
X Air - VF GTS CAI
Forced Induction interchillers, package
Brodix BR7-3 Heads
Pacemaker ceramic coated 1/7/8th Headers DiFillipo 3 inch twin system
RoushSenator is online now
post #7 of 41 (permalink) Old 04-25-2019, 12:27 AM
Senior Member
a6d9cmro's Avatar
Garage
i've often wondered if fans could be put on the HX and triggered via thermostat switch...I need to get my setup installed so, guess i will find out...
2017 SBM M6
20x9 255/30/20 ET35
20x11 305/30/20 ET54
Rotofab- Kazoo tube delete
Hurst Shifter: 3916030 with pit pack extreme duty bushing and Pegasus poly shifter bushing
VMAX PTB
Z06 6 piston vented brakes
To be installed:
PRC260 heads
Cam Motion PDS cam XA232/365-XA246/355-18+4
Jokerz LSA w-Griptech 2.55- 8 rib config - FIC1050- Upgraded HX - Varimax pump
Kooks 2" > Solo 3"
LS7 MAF upgrade
ATI balancer 10% OD
SSL springs front and rear
a6d9cmro is online now
post #8 of 41 (permalink) Old 04-25-2019, 06:17 AM
Senior Member
Just take a look. Is the sensor in the middle of the drivers side portion of the lid hooked up? It’s a brass sensor. The wiring to it will be coming from the maf sensor harness. Heat soak is a very real issue while sitting still.
Quote:
You can adjust how strong the fans come on based on a/c pressure. You could try this first before you commit to adding new fans and wiring. The higher the a/c pressure generally means the less flow over the condenser. If you start seeing lower iats you could leave it like that or add extra dedicated fans. I personally have mine turned up to help with killer chiller in traffic. It makes a big difference
a6d9cmro likes this.
post #9 of 41 (permalink) Old 04-25-2019, 06:54 AM
Senior Member
Bo799's Avatar
You could set your fans to come on earlier and it will help a little but it isnít going to work any magic.
Dsmer1 likes this.
2015 Heron White 6M hole in the roof and an extra wheel. 30 built this way.
Ported LSA w/2.55 pulley, BTR stage 3 PD cam, ZL1 rotofab, LS7 maf, ID850ís, Kooks longtubes, Camaro Resonators, solo axleback, Interchiller, Elite catchcan
Bo799 is offline
post #10 of 41 (permalink) Old 04-25-2019, 08:10 AM
Senior Member
Quote:
The factory fans are slow to ramp up to speed, they start around 20% of maximum capacity. Their normal settings are perfect for stock cars but once you start making changes and require more from them you need to change more than just kick on temp. Itís a bit of trial and error for each individual setup but a lot can be achieved with them. Just donít command them on below 192*
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
I found the guaranteed way to reduce IATs rao Chevy SS General Discussion Forum 17 01-02-2018 11:55 AM
Heater stuck on high after high speed run SLIHRSS16 Exterior and Interior 2 11-21-2017 10:51 AM
Crazy Paulís a great source for blackout trim OttoSS Exterior and Interior 16 09-23-2015 01:52 PM
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
