Oil in Catch Can, how much is too much?? - Chevy SS Forum
 20Likes
Reply
LinkBack Thread Tools
post #1 of 33 (permalink) Old 06-16-2019, 11:19 PM Thread Starter
Junior Member
jmadson09's Avatar
I have a Mighty Mouse catch can and will be draining it again for a third time since install. I feel like I'm collecting a lot of oil. Is this normal or could I have an issue?
jmadson09 is offline
Sponsored Links
Advertisement
post #2 of 33 (permalink) Old 06-16-2019, 11:27 PM
Senior Member
How much volume collects over how many miles? Unless it's hooked up wrong, you can't collect "too much". Would you rather that oil contaminate your intake charge, get burned in the combustion chamber, leave carbon deposits, cause knock, and make the computer to pull timing? If it's collecting a lot of oil and it's hooked up correctly, it's just doing what it was designed to do.
SS_Scott likes this.
Murky is online now
post #3 of 33 (permalink) Old 06-16-2019, 11:35 PM
Garage
How much is a lot? How many miles between each clean out? Manual or automatic? Aggressive or conservative driving style? The more info you give us, the more we can help.
willy92 and SS_Scott like this.
15SuperSport is offline
post #4 of 33 (permalink) Old 06-16-2019, 11:42 PM
Senior Member
SS_Scott's Avatar
Garage
Quote:
I don't have much experience with my can on my SS yet.
I can tell you on my v6 Colorado p/u it collects about 1 oz. per 1000 miles. Judging by others with the same trucks it is very close to that with them too.
Without getting all geeked out on oil and it's specs, it most likely depends mostly on the NOACK Volatility of the oil in question. In my limited experience I would say any full syn is good and performs well in that test.
Anyway, I'm keeping tabs on my SS but it is too soon to tell. I'm betting it will be close to an oz. per 1k miles with the LS3 just like the LFX in my Colorado.
Also, the more wear on the rings/cyl/pistons the more you will likely see. I can tell you this, it was much more than I expected, that's for sure. It is amazing how much those little cans collect.
EDIT: Measure the amount and mileage and report back, I'm curious, maybe others are too.
Sent from the butt crack of California
2016 white, auto V-8 Malibu. All stock except for catch can and high performance muffler bearings.
SS_Scott is offline
post #5 of 33 (permalink) Old 06-17-2019, 12:27 AM
Senior Member
good2go's Avatar
Also consider that it may be that not all that is collected is oil. There can be a lot of condensation and other liquefied gaseous content in the mix. It's often a regular smorgasbord of ilk collected in the cans. Be sure and correlate the volume you are collecting with the current oil levels (on an accurate read of the dipstick) and see if it jives.
SS_Voraus, SilverSport and wilkin4 like this.
2016 HW M6, no roof, no spare!
good2go is online now
post #6 of 33 (permalink) Old 06-17-2019, 02:35 AM
Senior Member
SS_Scott's Avatar
Garage
Quote:
T
Yes, in warm climates it seams to be just an oily kind of "stuff". Much like used oil. That's what I find, just like you forgot to change your oil for a while kind of stuff....
In colder climates you can get a kind of 'milkshake' looking stuff that appears to be from moisture.
I really don't think it's a big deal on our port injection, but on a GDI engine it is a must for me to have a catch can.
pottypants likes this.
SS_Scott is offline
post #7 of 33 (permalink) Old 06-17-2019, 09:21 AM
Senior Member
BillGsa's Avatar
I installed mine at 25,000 miles. I just emptied it at 26,200 miles...about a 1/2 ounce.
15 SIM Auto Roof No Spare, it does now
Livernois Tune, Rotofab
Kooks Headers & Mid Pipe
19 XT4 The Wife's
15 BMW R1200GSA
BillGsa is online now
post #8 of 33 (permalink) Old 06-17-2019, 09:27 AM
Senior Member
I installed my Elite can at about 1k miles (would've been earlier but thanks Maryland Speed ) and for the most part it pretty consistently would be about 3/4 filled every 3k miles. Last oil change at 26k it seemed like the rate decreased a bit. Could be the rings finished seating by 20k miles and compression is a hair better resulting in less blowby.
2016 Chevy SS HW - can, Rotofab, 1-7/8 ARH headers +cats and LMS tune
2001 Trans Am NHRA Edition - TSP built Darton sleeved 454 and a lot of other stuff
NHRATA01 is online now
post #9 of 33 (permalink) Old 06-17-2019, 09:48 AM
Senior Member
Quote:
Originally Posted by NHRATA01 View Post
I installed my Elite can at about 1k miles (would've been earlier but thanks Maryland Speed [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG] ) and for the most part it pretty consistently would be about 3/4 filled every 3k miles. Last oil change at 26k it seemed like the rate decreased a bit. Could be the rings finished seating by 20k miles and compression is a hair better resulting in less blowby.
3/4 full after 3k miles???
Something is very wrong. I had about a 1/4 cup in mine after 5k miles and I thought that was a lot.
MichaelSS15 is online now
post #10 of 33 (permalink) Old 06-17-2019, 11:44 AM
Senior Member
I have a catch can on my truck (5.7 Hemi) and on my SS. I dump the one on my truck more often than the SS since (according to the forums) the hemis are known for having more "blowback" than the LS motors. I will dump the one in my SS maybe 2 or 3 times between oil changes, about a have dozen or more for the truck. I never let it get more than half full.
'15 M6 Perfect Blue, Roof, Inflator. #20 of 21.
RCFiddyOne is online now
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
