Under the knife is a beautiful 2016 Chevrolet SS Sedan. We will be taking this from mild to wild in no time! We are sticking with a N/A setup instead of adding any forced induction. This package is the Livernois Motorsports 560 package. For more details or to order, give us a call at (313) 561-5500 or email us at info@livernoismotorsports.com
Mod List;
Livernois Motorsports Powerstorm Stage 2 Heads
Livernois Motorsports Powerstorm 2C-HL Camshaft
Livernois Motorsports Powerstorm Billet Rocker Brases
Livernois Motorsports EvenFlo Thermostat
Livernois Motorsports Custom Dyno Tuning and MyCalibrator Tuner
Livernois Motorsports Selected Cold Air Intake
Ported Manifold and Throttle Body
Upgraded Push Rods
3-Bolt Timing Sprocket
ARP Cam Bolts
GMPP Balancer Bolt
GMPP Head Gasket
ARP Head Bolts
After the baseline testing, we have started to pull the stock CAI off. Next we will be getting the throttle body and intake over to the Cylinder Head department for porting.
Very nearly, as far as I can tell. I think this is a fairly standard package for Livernois. A well traveled road for them. Lets see if the final RHP is about 470.
Intake and throttle body are off. The next step is to send these over to the cylinder head department for porting. Our goal is to increase air flow as much as possible to gain every bit of HP we can.
The Livernois Pro Series product line is built for customers who are looking for products that offer a no compromise approach. The components and services used in these products are in most cases custom designed proprietary parts that are based off of years of development and the latest in racing technology. These proprietary designs and parts are available only through Livernois Motorsports. Each and every product in the Pro Series line has been developed and tested in a rigorous R&D process to produce only the highest quality most durable products on the market. The extensive design time that goes into making a product for the Pro Series line involves a complete and systematic approach to the entire product and its lifecycle. Each part is designed and tested to work together as a system to maximize power and durability. The Livernois Pro Series line of products includes parts from industry leaders in their fields such as Manley, Callies, ARP, Carillo, Diamond, Ross and Clevite to name a few. Every aspect of the design, testing and final product machining and assembly are handled in house. This allows for complete control of the entire process start to finish. The latest in technologies are used in the design and testing of these products and components, including FEA (Finite Element Analysis), CFD (Computational Fluid Dynamics), as well as some of the latest CNC and CAD technologies available.
These braces improve the valvetrain and rocker arm control by adding strength and rigidity. When adding larger camshafts and spring pressures, the factory OE rocker stand and bolts can flex and distort. This can lead to lost valve motion as the rocker arm deflects on the stand. The Powerstorm Rocker Arm Brace helps keep rocker motion more true, and the added clamping load from the upgraded bolt helps to prevent rocker shift at higher loads.
Features include:
Premium 6061-T6 Billet Aluminum Material
Increased Cross Sectional Area for Added Resistance to Flex & Distortion
Wider Rocker Supports for Increased Rocker Arm Stability
With this setup and similar setups that choose to port, we will see about a 15 to 20whp gain. The increased air flow helps to pack even more power out of the setup.
I expect @IMPULSS is going to be a happy man soon.
He will likely have the hp to edge me out with his dual mode exhaust.
Related Threads
Chevy SS Forum
619.2K posts
17.7K members
Since 2012
