A DRL "override switch" was put on my 2014 SS back in August 2014. I also put one on my last (2011 GM car) in 2012, and both were without issues.
The way it works is as follows: Some points are not absolute.
When you start up your SS and the Daytime Running Lights (DRL) are on, you can then turn the (spring-loaded) round headlight knob to the left, and the DRLs will turn off until the car is restarted etc. If you restart your SS, and want the DRL off again, you have to do the same all over, (turn the knob) each time. However, a switch can be added that would ground the DRL and keep the DRLs off until you click the switch again.
NOTE: One reason the DRL does not stay off upon restarting your SS is because the headlight round knob switch is spring loaded, and after grounding the DRL it returns to its original position and does not hold the ground to the DRL OEM switch.
ADDING the DRL OVERRIDE SWITCH, without modification:
The DRL added override switch can be added without any modification to your SS. In other words, the ground wire will ground to an existing screw that is already on the SS's frame. The wire splice clip that is added to the DRL's wire is a (no splice clip), and can be unclipped from the DRL's wire without modification.
AS FOR CUTTING INTO THE DRL'S cover as I did, don't cut. In other words, hang the added switch somewhere until you have played with the functions of the added switch, and like them. Then if so desired, mount the switch somewhere, anywhere. You still do not have to add the switch to the DRL's cover or cut it. You can put the switch anywhere you like, without mounting it to the DRL's cover.
Other points about the DRL, among many:
When you turn the headlight round knob switch to the left, the current SS headlight switch grounds a green/brown wire on the back of the DRL switch. Once this wire is grounded, and as long as it is grounded, the DRLs will stay off. Not only will the DRLs stay off when grounded (green/brown wire), they will not return to automatic unless ungrounded.
Here is where the added DRL override switch comes into play. All the switch does is grounds the GREEN/BROWN wire when "clicked on" and holds the ground to the DRL. However, upon hitting the switch again, the DRL becomes ungrounded and the SS's DRL switch returns to normal. Again, the added switch simply holds the ground to the SS's OEM DRL switch.
Note, upon hitting the added DRL override switch to turn the DRLs on or back off, your dash will still indicate that the DRLs have been turned on or off.
If the added DRL override switch is "on" (grounded), the headlights will have to be manually turned on.
Pics explained:
Pic 01 and 02 Shows the parts needed to make a DRL override switch, about $5.00.
Pic 03 and 04 Shows steps (1 2 3 and 4) how to take the DRL apart without tools. In fact, it may be better to use your fingers only.
Pic 05 Shows one wire grounded to the SS's body. Ground screw used is already on the SS.
Pic 06 Ground wire and switch fed through to the DRL switch.
Pic 07and 08 Shows the (no splice clip), clipped onto the Green/Brown wire on the DRL's plug.
Pic 09 Shows the switch added to the SS's DRL switch cover.
Pic 10 DONE.
Ps. I will do another proof read after I post.
Hope this helps.
Pics explained:
Pic 10 DONE.
Hope this helps.
