95 SS Idles and dies/Check engine light questions - Chevy SS Forum
 7Likes
  • 1 Post By Ssouto
  • 2 Post By BishopSS
  • 1 Post By Pinetree
  • 1 Post By SSedan
  • 1 Post By nnrd79a
  • 1 Post By SSedan
LinkBack Thread Tools
post #1 of 9 (permalink) Old 01-10-2017, 12:20 PM Thread Starter
Junior Member
I have a 95 impala SS that sputters and dies when idle. It doesn't do it all the time but it has been lately in traffic when coming to stops. I notice it mostly when I give it gas then hit the brake. I can feel the car pull and the rpms sound like they're going up. I'm wondering if it's the IAC?
I have a check engine that comes and goes. I'm sure it has something to do with the issues at hand, will an innova 3123 scanner work on this car? I have a 12 pin OBDI connector but I've been hearing things about how some 95's have the OBDI connections but OBDII wiring?
Third question is the check engine light ALWAYS goes on for sure and stays on when I give the car a hard acceleration. The car pulls there's a clunk sound and it loses power. I have to turn it off and restart it then the gas peddle feels fine again. Any ideas?
I've taken the car to a few mechanics and nonone seems to figure it out. I'm trying to pinpoint and change these things on my own. I appreciate any help thanks forum.
Ssouto is offline
Sponsored Links
Advertisement
post #2 of 9 (permalink) Old 01-10-2017, 12:24 PM
Senior Member
Your on 2014-2017 chevy SS sedan site more info you likely find on impala forum.
PBM
No Roof No spare
chevyman2 is offline
post #3 of 9 (permalink) Old 01-10-2017, 12:26 PM Thread Starter
Junior Member
Quote:
Originally Posted by chevyman2 View Post
Your on 201-2017 chevy SS sedan site more info you likely find on impala forum.
Didn't catch that. I'm multitasking at work thanks
KenzSS likes this.
Ssouto is offline
post #4 of 9 (permalink) Old 01-10-2017, 01:16 PM
Junior Member
Long live the Opti Spark.
KenzSS and s/c'd cav like this.
2016 SS
2002 Camaro LE SS
1995 Impala SS
BishopSS is offline
post #5 of 9 (permalink) Old 01-10-2017, 01:43 PM
Member
nnrd79a's Avatar
Just a guess, as I am not there, but it sounds like your EGR valve is sticking open / closing slowly. (For dying when slowing down or coming to a stop)
Good Luck.
nnrd79a is online now
post #6 of 9 (permalink) Old 01-10-2017, 05:44 PM
Pinetree's Avatar
Garage
But you are also welcome here Ssouto! Maybe there's a current edition SS in your future. Many of us here have owned or still own the '94-'96 edition of the Impala SS.
KenzSS likes this.
Martin
2014 SS, Heron White, A6, no mods, #3334 of MY2014
and 41 of 41 as built of the 534 HW. Born on Feb 6, 2014.
2016 Silverado 1500 LTZ CC Summit White.
2014 Production stats:
2015 Production stats:
2016 Production Stats:
Pinetree is offline
post #7 of 9 (permalink) Old 01-10-2017, 08:30 PM
Senior Member
Just incase the OP comes back, that scanner wont work, it is a glorified paperclip and that style scanner does not work on the advanced OBD1 in the 94-5 b-bodies.
EGR is a common source of trouble on those, but so is horrible ignition neglect by owners. Since the opt is hard to get to and more expensive than most distributor caps it gets neglected till failure where most distributors have caps and rotors changed as a matter of routine maintenance.
IAC is worth cleaning.
Might unplug the electrical connection to the EGR solenoid so it doesn't try to open potentially stick open and see if that changes the symptoms.
Might check to see that there is flow through the opti vent harness too, plugged harness can result in vacuum in the distributor and spark scatter.
KenzSS likes this.
SSedan is online now
post #8 of 9 (permalink) Old 01-10-2017, 09:04 PM
Member
nnrd79a's Avatar
I've built a number of LT1's.
They aren't that bad.
The worst thing is the non-keyed crank for the HB.
Pull the water pump to access the opti.
Doesn't take that long.
What usually kills the opti is a weeping water pump.
Easy fix is to tap in a small drain into the weep hole and run a small piece of hose from tap to ... Somewhere else.. :-)
The EGR is vacuum controled on the LT1.
That's my two cents...
Again good luck.
KenzSS likes this.
post #9 of 9 (permalink) Old 01-10-2017, 09:54 PM
Senior Member
Yes the EGR is vacuum controlled but the vacuum is controlled by an electric solenoid.
KenzSS likes this.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
